Ga door naar hoofdinhoud
LG G4 Headphone Port Replacement
Wat je nodig hebt
  1. LG G4 Headphone Port Replacement, Back Cover: stap 1, afbeelding 1 van 1
    • Make sure the phone is powered off.
    • Remove the rear cover by placing the plastic opening tool in the groove on the bottom left side of the LG G4 and gently prying up.
  2. LG G4 Headphone Port Replacement: stap 2, afbeelding 1 van 2 LG G4 Headphone Port Replacement: stap 2, afbeelding 2 van 2
    • Place the plastic opening tool at the bottom edge of the battery and lift up. Carefully remove battery with your hands.
  3. LG G4 Headphone Port Replacement: stap 3, afbeelding 1 van 3 LG G4 Headphone Port Replacement: stap 3, afbeelding 2 van 3 LG G4 Headphone Port Replacement: stap 3, afbeelding 3 van 3
    • Remove the eleven 3.9 mm Phillips #00 screws found at the back of the phone.
  4. LG G4 Headphone Port Replacement: stap 4, afbeelding 1 van 3 LG G4 Headphone Port Replacement: stap 4, afbeelding 2 van 3 LG G4 Headphone Port Replacement: stap 4, afbeelding 3 van 3
    • Once all the screws have been removed, place the plastic opening tool in the lower left corner and firmly lift the cover up.
    • Detach the cover with your fingers
  5. LG G4 Headphone Port Replacement, Headphone Port: stap 5, afbeelding 1 van 2 LG G4 Headphone Port Replacement, Headphone Port: stap 5, afbeelding 2 van 2
    • Gently wedge the plastic opening tool under the ribbons where each of the three cables are connected, and gently lift up to detach the cable.
    • This will allow you to remove the motherboard and give access the headphone port.
  6. LG G4 Headphone Port Replacement: stap 6, afbeelding 1 van 2 LG G4 Headphone Port Replacement: stap 6, afbeelding 2 van 2
    • Remove the motherboard by lifting it up using the plastic opening tool and your fingers .
  7. LG G4 Headphone Port Replacement: stap 7, afbeelding 1 van 2 LG G4 Headphone Port Replacement: stap 7, afbeelding 2 van 2
    • Place the plastic opening tool under the upper left corner of the headphone port, and lift up.
    • The headphone port is held in place with adhesive so it may take some time to pry it loose.
    • Remove the headphone port with your hands.
Conclusie
7 andere personen hebben deze handleiding voltooid.
Austin Stratton
1.576 Reputatie
4 handleidingen geschreven
USF Tampa, Team 16-5, Wollert Fall 2015 Lid van USF Tampa, Team 16-5, Wollert Fall 2015
USFT-WOLLERT-F15S16G5
4 Leden
15 handleidingen geschreven
8 opmerkingen
In step 5, there are actually three cables, not two.
krdkrdkrd - Antwoord
My g4's headphone could only produce sound on one side. So i bought a new headphone jack from ebay and replaced it. The problem still persists. Does this mean it could be a motherboard issue?
pholklorr - Antwoord
Or a headphone issue. You did try a different pair of headphones?
DarkAthena -
i did the same as pholklorr with my g4 but bought oem and still doesn't work you can only hear it from one side
titanzx2500 - Antwoord
Great! My headphone port couldn't hold my headphones anymore because of wear & tear (they kept falling out) but this guide and a 6 dollar ebay-item fixed it! Thanks a lot.
Moritz Bruder - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 13
Altijd: 8,812
