Ga door naar hoofdinhoud
LG G4 Front Camera Replacement
Wat je nodig hebt
  1. LG G4 Front Camera Replacement, Back Cover: stap 1, afbeelding 1 van 1
    • Make sure the phone is powered off.
    • Remove the rear cover by placing the plastic opening tool in the groove on the bottom left side of the LG G4 and gently prying up.
  2. LG G4 Front Camera Replacement: stap 2, afbeelding 1 van 2 LG G4 Front Camera Replacement: stap 2, afbeelding 2 van 2
    • Place the plastic opening tool at the bottom edge of the battery and lift up. Carefully remove battery with your hands.
  3. LG G4 Front Camera Replacement: stap 3, afbeelding 1 van 3 LG G4 Front Camera Replacement: stap 3, afbeelding 2 van 3 LG G4 Front Camera Replacement: stap 3, afbeelding 3 van 3
    • Remove the eleven 3.9 mm Phillips #00 screws found at the back of the phone.
  4. LG G4 Front Camera Replacement: stap 4, afbeelding 1 van 3 LG G4 Front Camera Replacement: stap 4, afbeelding 2 van 3 LG G4 Front Camera Replacement: stap 4, afbeelding 3 van 3
    • Once all the screws have been removed, place the plastic opening tool in the lower left corner and firmly lift the cover up.
    • Detach the cover with your fingers
  5. LG G4 Front Camera Replacement, Front Camera: stap 5, afbeelding 1 van 3 LG G4 Front Camera Replacement, Front Camera: stap 5, afbeelding 2 van 3 LG G4 Front Camera Replacement, Front Camera: stap 5, afbeelding 3 van 3
    • Detach the Front Camera ribbon cable located on the top right corner of the back of the phone by gently lifting it up with a plastic opening tool. Remove the front camera.
    • Be careful when removing the cables and pulling out the front camera to avoid tearing the attached cable.
Conclusie
5 andere personen hebben deze handleiding voltooid.
Austin Stratton
1.582 Reputatie
4 handleidingen geschreven
USF Tampa, Team 16-5, Wollert Fall 2015 Lid van USF Tampa, Team 16-5, Wollert Fall 2015
USFT-WOLLERT-F15S16G5
4 Leden
20 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 11
Altijd: 4,279
