Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Remove the rear cover by placing the plastic opening tool in the groove on the bottom left side of the LG G4 and gently prying up.
Place the plastic opening tool at the bottom edge of the battery and lift up. Carefully remove battery with your hands.
Remove the eleven 3.9 mm Phillips #00 screws found at the back of the phone.
Once all the screws have been removed, place the plastic opening tool in the lower left corner and firmly lift the cover up.
Detach the cover with your fingers
9 andere personen hebben deze handleiding voltooid.
