Inleiding
Having technical issues with your LG G3 Vigor that are linked to your devices motherboard? You are in luck, this is the LG G3 Vigor motherboard replacement guide.
Wat je nodig hebt
Remove the twelve Phillips #00 screws securing the midframe to the rest of the phone.
Use the spudger to gently unplug the ribbon cable connected to the motherboard. Then remove the rear facing camera.
Remove the front camera.
Use the flat edge of a spudger to disconnect the motherboard ribbon connector.
8 andere personen hebben deze handleiding voltooid.
