Inleiding
Use this guide to replace the display assembly on your LG G3 Vigor.
Wat je nodig hebt
Remove the twelve Phillips #00 screws securing the midframe to the rest of the phone.
Use the spudger to gently unplug the ribbon cable connected to the motherboard. Then remove the rear facing camera.
Remove the front camera.
Use the flat edge of a spudger to disconnect the motherboard ribbon connector.
Remove the earpiece speaker with the metal spudger by prying it out.
Remove the headphone jack by inserting the spudger into the jack and pulling it up and out.
Gereedschap gebruikt in deze stap:Tweezers$4.99
Using tweezers peel back the glued down ribbon cable at the bottom of the phone.
Using a heat gun or the iFixit iOpener tool heat up the edges of the devices screen.
After a few minutes heating up the edges of the screen use a metal spudger tool or any other flat tool to dig under the edge of the screen.
Once under the edge of the screen work your way around the entire perimeter of the screen and pull the screen off.
6 andere personen hebben deze handleiding voltooid.
2 opmerkingen
i tried to replace the glass, the phone is now stuck at boot screen. the os would load occasionally before. possible battery/water problem. are there any hardware issue that would cause the boot screen (blinking red light)
Would anyone know a place to source the glass/lcd assembly. Mucho thanks!
