Inleiding
The Camera requires almost all of the phone to be dissected. Make sure to keep all screws and parts in a safe place to be easily reinstalled.
Wat je nodig hebt
Use a plastic opening tool to pry open your phone case. Flip the phone over and start by sliding your tool between the two sides of your phone case. Work the tool towards the bottom of the phone case, gently prying the case open. There is a clip that will pop open after applying gentle but consistent pressure.
Make sure to release the clip on the top left corner of the phone case carefully. This is usually the most difficult clip to release.
The rear facing camera is attached to the phone case with adhesive. Make sure to use your plastic prying tool to softly remove the camera from the case.
Één andere persoon heeft deze handleiding voltooid.
