Inleiding
Removing the power button might be useful when attempting to clean the device.
Wat je nodig hebt
Place the watch upside down on a hard surface so that its back case is facing upright.
Use a T4 Torx Star screwdriver to remove the four 4.0 mm Torx screws from the corners of the back case.
With a plastic opening tool, disconnect the four connectors on the top of the motherboard.
Pry the battery housing from the top right corner using a spudger.
Once loosened, remove the battery housing.
Gereedschap gebruikt in deze stap:Tweezers$4.99
On the power button, locate a small grey washer on the interior side of the watch.
Use a pair of tweezers or another pointed object to push the washer out of its socket, and remove the power button.
7 andere personen hebben deze handleiding voltooid.
