Ga door naar hoofdinhoud
LG G Watch R Battery Housing
Wat je nodig hebt
  1. LG G Watch R Battery Housing, Back Case: stap 1, afbeelding 1 van 2 LG G Watch R Battery Housing, Back Case: stap 1, afbeelding 2 van 2
    • Power off your watch before disassembling it.
    • Place the watch upside down on a hard surface so that its back case is facing upright.
    • Use a T4 Torx Star screwdriver to remove the four 4.0 mm Torx screws from the corners of the back case.
  2. LG G Watch R Battery Housing: stap 2, afbeelding 1 van 1
    • Use a plastic opening tool to pry open the back case from both sides of the watch.
  3. LG G Watch R Battery Housing: stap 3, afbeelding 1 van 1
    • Remove the back case.
  4. LG G Watch R Battery Housing, Motherboard: stap 4, afbeelding 1 van 2 LG G Watch R Battery Housing, Motherboard: stap 4, afbeelding 2 van 2
    • With a plastic opening tool, disconnect the four connectors on the top of the motherboard.
  5. LG G Watch R Battery Housing: stap 5, afbeelding 1 van 2 LG G Watch R Battery Housing: stap 5, afbeelding 2 van 2
    • Remove three 3.0 mm Phillips screws on the edges of the motherboard with a Phillips #000 screwdriver.
  6. LG G Watch R Battery Housing: stap 6, afbeelding 1 van 1
    • Grasp the edges of the motherboard and slide it slightly towards the right to remove it from its case.
  7. LG G Watch R Battery Housing, Battery Replacement: stap 7, afbeelding 1 van 1
    • Use a plastic opening tool to pry the battery out of the device.
    • You may need to use a stronger prying force due to the adhesive that secures the battery to the case.
  8. LG G Watch R Battery Housing, Battery Housing Replacement: stap 8, afbeelding 1 van 2 LG G Watch R Battery Housing, Battery Housing Replacement: stap 8, afbeelding 2 van 2
    • Pry the battery housing from the top right corner using a spudger.
    • Once loosened, remove the battery housing.
Conclusie
Westley Courchene
3.341 Reputatie
14 handleidingen geschreven
USF Tampa, Team 1-1, Remmell Fall 2015 Lid van USF Tampa, Team 1-1, Remmell Fall 2015
USFT-REMMELL-F15S1G1
5 Leden
Één opmerking
Hi there, do you know where can i buy the battery housing? Thank you..
Eugene Kang - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 1,491
