Ga door naar hoofdinhoud
LG G Watch Motherboard Replacement
Wat je nodig hebt
  1. LG G Watch Motherboard Replacement, Wristband: stap 1, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    • Spring bars attach the two halves of the wristband to the watch body. The spring bar has a shoulder on either end.
    • Be prepared to apply some pressure with your fingers to perform the following action.
    • First, slide the wristband down on the spring bar to expose the shoulder of the spring bar.
    • Grasp the exposed shoulder with the tweezers to perform the next step.
  2. LG G Watch Motherboard Replacement: stap 2, afbeelding 1 van 2 LG G Watch Motherboard Replacement: stap 2, afbeelding 2 van 2
    • This is a challenging step. Do it carefully to prevent the spring bar from flying out of the wristband.
    • Use the tweezer to depress the spring bar so that it collapses by a few millimeters and pops out of the hole that was holding it in place.
    • Now carefully pull the other end of the spring bar to detach the wristband from the watch face.
    • Repeat steps 1 and 2 for the other wristband.
  3. LG G Watch Motherboard Replacement, Rear Case: stap 3, afbeelding 1 van 1
    • Use the T5 Torx screwdriver to unscrew the four silver 2mm x 3mm T5 screws that hold the back cover in place.
  4. LG G Watch Motherboard Replacement: stap 4, afbeelding 1 van 2 LG G Watch Motherboard Replacement: stap 4, afbeelding 2 van 2
    • Slide the opening pick between the rear case and the rest of the device to separate the two halves.
    • Gently pull the two halves apart.
  5. LG G Watch Motherboard Replacement, Gasket: stap 5, afbeelding 1 van 1
    • Use a pair of tweezers to remove the gasket that lies embedded in a groove that runs around the perimeter of the front half.
  6. LG G Watch Motherboard Replacement, Motherboard: stap 6, afbeelding 1 van 2 LG G Watch Motherboard Replacement, Motherboard: stap 6, afbeelding 2 van 2
    • Use the spudger to gently lift up and disconnect the display connector.
    • Now use the spudger to disconnect the digitizer connector.
  7. LG G Watch Motherboard Replacement: stap 7, afbeelding 1 van 2 LG G Watch Motherboard Replacement: stap 7, afbeelding 2 van 2
    • Use a Phillips #000 screwdriver to remove the two black PHO 2.5mm x 3mm screws.
    • Use the spudger to gently remove the motherboard.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Meles Anneaud
140 Reputatie
1 Handleiding geschreven
USF Tampa, Team 2-5, Blackwell Fall 2014 Lid van USF Tampa, Team 2-5, Blackwell Fall 2014
USFT-BLACKWELL-F14S2G5
5 Leden
9 handleidingen geschreven
1Gids Commentaar
is it possible to replace the battery which is in the board?
Vassago U7 (VassagoU7) - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 9
Altijd: 1,087
