Ga door naar hoofdinhoud
LG G Vista Charging Dock Replacement
Wat je nodig hebt
  1. LG G Vista Charging Dock Replacement, Battery: stap 1, afbeelding 1 van 1
    • Make sure the device is powered off.
  2. LG G Vista Charging Dock Replacement: stap 2, afbeelding 1 van 1
    • Remove the back cover by gently prying open the case of the device from the charging port.
  3. LG G Vista Charging Dock Replacement: stap 3, afbeelding 1 van 1
    • Lift the battery out of its place by prying up from the small notch at the base of the battery.
  4. LG G Vista Charging Dock Replacement, Charging Dock: stap 4, afbeelding 1 van 1
    • Using a Phillips #000 screwdriver, remove the eleven 3.0 mm screws around the perimeter of the phone.
  5. LG G Vista Charging Dock Replacement: stap 5, afbeelding 1 van 1
    • Use a plastic spudger, or finger nail, to lift up the hard shell on the top of the phone.
  6. LG G Vista Charging Dock Replacement: stap 6, afbeelding 1 van 2 LG G Vista Charging Dock Replacement: stap 6, afbeelding 2 van 2
    • Use a Phillips #000 screwdriver to remove the five 3.0 mm screws.
    • Remove the bottom hard shell from the device.
  7. LG G Vista Charging Dock Replacement: stap 7, afbeelding 1 van 2 LG G Vista Charging Dock Replacement: stap 7, afbeelding 2 van 2
    • Using a Phillips #000 screwdriver, remove the two screws from the device.
  8. LG G Vista Charging Dock Replacement: stap 8, afbeelding 1 van 1
    • Using a pair of tweezers, lift up the two antennas surrounding the battery.
  9. LG G Vista Charging Dock Replacement: stap 9, afbeelding 1 van 1
    • Disconnect the two connectors on the right side of the charging port.
  10. LG G Vista Charging Dock Replacement: stap 10, afbeelding 1 van 1
    • Lift up the charging port with the plastic opening tool.
    • Remove the charging port from the device.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 12
Altijd: 638
