Ga door naar hoofdinhoud
LG G Stylo Battery Replacement
Wat je nodig hebt
  1. LG G Stylo Battery Replacement, Battery: stap 1, afbeelding 1 van 2 LG G Stylo Battery Replacement, Battery: stap 1, afbeelding 2 van 2
    • Make sure that you power off the phone before beginning.
    • Remove the back cover by placing the plastic opening tool on the bottom left side of the device and gently prying up.
    • There is a small slit that fits the plastic opening tool perfectly on the left side.
  2. LG G Stylo Battery Replacement: stap 2, afbeelding 1 van 2 LG G Stylo Battery Replacement: stap 2, afbeelding 2 van 2
    • Insert the plastic opening tool into the indent at the bottom of the battery and lift up. Fully remove the battery with your fingers.
Conclusie
6 andere personen hebben deze handleiding voltooid.
Douglas Schmidt
422 Reputatie
2 handleidingen geschreven
USF Tampa, Team 11-7, Cheng Spring 2016 Lid van USF Tampa, Team 11-7, Cheng Spring 2016
USFT-CHENG-S16S11G7
4 Leden
14 handleidingen geschreven
Één opmerking
Thank you for your help. This has been making us crazy, your time is much appreciated.
Desi Young - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 6
Afgelopen 7 dagen: 17
Afgelopen 30 dagen: 62
Altijd: 12,864
