Ga door naar hoofdinhoud
LG G Pad X 8.3 Battery Replacement
Wat je nodig hebt
  1. LG G Pad X 8.3 Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Remove the cover of the SD card. Find it on the right side of the back of the tablet.
    • Press the SD card in to make it pop out.
  2. LG G Pad X 8.3 Battery Replacement: stap 2, afbeelding 1 van 1
    • Slide the stylus out from the bottom left corner of the back panel.
  3. LG G Pad X 8.3 Battery Replacement: stap 3, afbeelding 1 van 1
    • Start at a corner and pry the screen up with a plastic opening tool.
    • You can also use a plastic spudger for this task, but do not use metal tools. They can be dangerous to you and the device.
    • Slide the tool in the seam at the edge of the screen.
    • Wedge additional plastic opening tools in the seam to help lift the screen.
    • Slide both wedged plastic opening tools towards the bottom to pop the screen loose.
    • If your screen is cracked, work slowly to avoid flinging glass shards when prying.
  4. LG G Pad X 8.3 Battery Replacement: stap 4, afbeelding 1 van 3 LG G Pad X 8.3 Battery Replacement: stap 4, afbeelding 2 van 3 LG G Pad X 8.3 Battery Replacement: stap 4, afbeelding 3 van 3
    • With a Phillips #000 screwdriver, unscrew the six 4.0 mm screws that hold down the battery.
    • With the Phillips #000 screwdriver, unscrew the two 4.0 mm screws that hold down the battery ribbon connector.
    • Use a magnetic mat to keep track of these tiny screws for later reassembly.
  5. LG G Pad X 8.3 Battery Replacement: stap 5, afbeelding 1 van 1
    • Lift the battery ribbon connector with your finger.
  6. LG G Pad X 8.3 Battery Replacement: stap 6, afbeelding 1 van 1
    • Lift the battery with your fingers and remove it from the device.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
2 opmerkingen
This looks to be a helpful Guide, but there is no help in WHERE to purchase a battery and if there could be a different battery with higher capacity and a longer life as a choice. As a Consumer, this type of information would be helpful.
Harvey Rothenberg - Antwoord
I cannot get a wedge tool in to remove the screen on my LG G Pad X 10.1. Any suggestions?
Hillary Brandeberry - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 16
Altijd: 5,312
