Ga door naar hoofdinhoud
LG G Pad F 8.0 Screen Replacement
Wat je nodig hebt
  1. LG G Pad F 8.0 Screen Replacement, Screen: stap 1, afbeelding 1 van 2 LG G Pad F 8.0 Screen Replacement, Screen: stap 1, afbeelding 2 van 2
    • Place the tablet with the screen facing down.
    • Open the SIM port on the top right corner of the tablet.
    • Press the SIM card to pop it out.
    • Remove the SIM card from the tablet.
  2. LG G Pad F 8.0 Screen Replacement: stap 2, afbeelding 1 van 2 LG G Pad F 8.0 Screen Replacement: stap 2, afbeelding 2 van 2
    • Use the iFixit opening tool to pry the plastic backing off of the internal block.
    • Do this by finding the seam between the edge of the screen and the plastic backing, and prying between the two.
    • Work your way all the way around the edge of the screen, and remove the plastic backing when it is loose.
Conclusie
Noah Trevino
353 Reputatie
3 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 31
Altijd: 360
