Wat je nodig hebt
Open up the SIM port, on the top right corner (screen face down).
Press the SIM card (white plastic) to pop it out.
Remove SIM card and set aside.
Use the plastic opening tool to pry the plastic backing off of the internal block. Start at the location with the SIM port to avoid damage to internal components.
Do this by finding the seam between the edge of the screen and the plastic backing, and prying between the two.
Work your way all the way around the edge of the screen, and remove the plastic backing when it is loose.
7 andere personen hebben deze handleiding voltooid.
4 opmerkingen
Good work, Pictures are clear and easy to follow
Just a minor item. On step 4 it tells you to remove the gyroscope, then remove the speaker. On on the unit I worked in you had to remove the speaker so you could get remove the gyroscope. I was working on the 8.0 instead of the 7.0 model, so perhaps that accounted for the difference.
Where do you buy the new charging port you need to put in? It's like gold lined teeth top and bottom.
Also on his LG can we turn it into a prepaid monthly service if we get a at&t sim card kit or something similar?
