Ga door naar hoofdinhoud
LG G Pad 8.3 Volume Control Buttons Replacement
Wat je nodig hebt
  1. LG G Pad 8.3 Volume Control Buttons Replacement, Back Panel: stap 1, afbeelding 1 van 2 LG G Pad 8.3 Volume Control Buttons Replacement, Back Panel: stap 1, afbeelding 2 van 2
    • With the tablet face down, pull the SD card slot cover out.
    • Using a Phillips #000 screwdriver, remove the 3mm screw located in the SD card slot.
  2. LG G Pad 8.3 Volume Control Buttons Replacement: stap 2, afbeelding 1 van 3 LG G Pad 8.3 Volume Control Buttons Replacement: stap 2, afbeelding 2 van 3 LG G Pad 8.3 Volume Control Buttons Replacement: stap 2, afbeelding 3 van 3
    • Insert a plastic opening tool in the small crevasse between the screen and the back panel.
    • Pry the screen away from the back panel.
    • Repeat this on each edge of the device.
    • We found it helpful to leave multiple plastic opening tools wedged in the crevasse to prevent it from closing.
    • This requires heavy force. The back of the device is attached with an adhesive. If the back panel is too hard to remove, use the iOpener.
  3. LG G Pad 8.3 Volume Control Buttons Replacement: stap 3, afbeelding 1 van 2 LG G Pad 8.3 Volume Control Buttons Replacement: stap 3, afbeelding 2 van 2
    • After using the plastic opening tools, pry the device open with your hands.
    • Remove the back panel from the screen.
  4. LG G Pad 8.3 Volume Control Buttons Replacement, Volume Control Buttons: stap 4, afbeelding 1 van 2 LG G Pad 8.3 Volume Control Buttons Replacement, Volume Control Buttons: stap 4, afbeelding 2 van 2
    • With the screen facing towards you and the top of the tablet towards your left, locate the volume buttons on the left side.
    • Using a spudger or your hands, remove the volume control buttons, which are attached with adhesive.
Conclusie
Mario Salguero
781 Reputatie
6 handleidingen geschreven
CSU Fullerton, Team 1-6, Bruce Fall 2015 Lid van CSU Fullerton, Team 1-6, Bruce Fall 2015
CSUF-BRUCE-F15S1G6
4 Leden
14 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 7
Altijd: 1,047
