Inleiding
If your LG G Pad 8.3 speaker isn't working, it may be time to replace it. This guide will show you how to replace the speaker.
Wat je nodig hebt
With the tablet face down, pull the SD card slot cover out.
Using a Phillips #000 screwdriver, remove the 3mm screw located in the SD card slot.
Remove the four 3 mm Phillips #000 screws that are attached to the speaker.
4 andere personen hebben deze handleiding voltooid.
