Ga door naar hoofdinhoud
LG G Pad 7.0 LTE Motherboard Replacement
Wat je nodig hebt
  1. LG G Pad 7.0 LTE Motherboard Replacement, Removing the Back Cover: stap 1, afbeelding 1 van 1
    • Power off your device before beginning the battery replacement (hold the button with the red marker until the device prompts you to power it off, then tap "Power Off").
    • Be wary of the front screen and SIM Card while tearing down the device.
  2. LG G Pad 7.0 LTE Motherboard Replacement: stap 2, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Anti-Static Wrist Strap
    $7.95
    Koop
    • Put on an Anti-Static Wrist Strap to prevent damage to sensitive electrical components (optional).
    • To separate the frame from the cover, pry between the screen and the cover using a plastic prying tool.
    • Begin at the top left of the device to avoid damaging the motherboard and work your way around the perimeter of the screen.
    • When you pry your device open, be wary of the volume rockers, motherboard, and camera. These components are delicate and can be sensitive to static electricity.
  3. LG G Pad 7.0 LTE Motherboard Replacement, Motherboard: stap 3, afbeelding 1 van 1
    • Disconnect the battery connector by prying it upwards (red marker).
    • Be careful not to damage it while doing so.
    • Remove the ribbon cables by prying them upwards with a plastic pry tool ).
    • Do not bend the cable or connector as they are fragile.
  4. LG G Pad 7.0 LTE Motherboard Replacement: stap 4, afbeelding 1 van 1
    Koop
    • There is a light adhesive holding the camera in the device.
    • Using tweezers or a small plastic pry tool gently pull or pry the camera out of the device.
  5. LG G Pad 7.0 LTE Motherboard Replacement: stap 5, afbeelding 1 van 1
    • Pry the audio jack from the device using a spudger.
  6. LG G Pad 7.0 LTE Motherboard Replacement: stap 6, afbeelding 1 van 1
    • Remove the 7 Black 3mm PH0 screws from the motherboard (red markers).
  7. LG G Pad 7.0 LTE Motherboard Replacement: stap 7, afbeelding 1 van 1
    • Remove the Motherboard.
Conclusie
Fadi Bitar
880 Reputatie
6 handleidingen geschreven
USF Tampa, Team 14-6, Eyestone Fall 2016 Lid van USF Tampa, Team 14-6, Eyestone Fall 2016
USFT-EYESTONE-F16S14G6
4 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 8
Altijd: 559
