Ga door naar hoofdinhoud
LG G Pad 7.0 Battery Replacement
Wat je nodig hebt
  1. LG G Pad 7.0 Battery Replacement, Front Panel: stap 1, afbeelding 1 van 2 LG G Pad 7.0 Battery Replacement, Front Panel: stap 1, afbeelding 2 van 2
    • The screen assembly is secured to the plastic backing with clips. Insert the spudger between the screen and plastic.
    • Work your way around the device, freeing it from the connecting clips.
    • Be careful around the MicroSD, sim card, power, and volume buttons
    • Attempt to lift the tablet from the plastic frame. You may need to loosen some more clips if it is difficult to remove.
  2. LG G Pad 7.0 Battery Replacement, Battery Connector: stap 2, afbeelding 1 van 3 LG G Pad 7.0 Battery Replacement, Battery Connector: stap 2, afbeelding 2 van 3 LG G Pad 7.0 Battery Replacement, Battery Connector: stap 2, afbeelding 3 van 3
    • Remove the battery connector marked in orange, by prying it upwards.You may need some force to do this, be careful not to damage anything.
    • Remove the other connector marked in red by gently prying up. Be sure not to rip the ribbon cables as they are very fragile.
  3. LG G Pad 7.0 Battery Replacement, Battery: stap 3, afbeelding 1 van 1
    • Gently pry the battery up making sure not to bend it or snag any cables.
    • The battery is secured by two pieces of double sided tape on the left and right edges under the battery.
    PERFECT instructions, Thanx.
    Now to find a new battery.
    D.A. Pawley - Antwoord
Conclusie
18 andere personen hebben deze handleiding voltooid.
echow2001
2.117 Reputatie
4 handleidingen geschreven
LGBTQ Technicians Lid van LGBTQ Technicians
Community
14 Leden
23 handleidingen geschreven
Één opmerking
Thank you for this guide. The iFixit tool worked much better than the one that came with the replacement battery. I needed a magnifying glass to verify I lined up the ribbon cable connector but other than that it went smoothly.
Juan Campos - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 38
Altijd: 17,341
