Ga door naar hoofdinhoud
LG G Pad 7.0 Battery Replacement
Wat je nodig hebt
  1. LG G Pad 7.0 Battery Replacement, LG G-Pad 7.0: stap 1, afbeelding 1 van 1
    • Here it is - LG G-Pad 7.0. Let's dive right in!
  2. LG G Pad 7.0 Battery Replacement, Jumping right into action: stap 2, afbeelding 1 van 2 LG G Pad 7.0 Battery Replacement, Jumping right into action: stap 2, afbeelding 2 van 2
    • First things first, use the handy pick iFixit sells on their online store. Carefully pry the frame apart in between the screen assembly an back cover. Be extremely careful, you don't want to damage the motherboard..
  3. LG G Pad 7.0 Battery Replacement, First Glimpse: stap 3, afbeelding 1 van 1
    • Vuala! We're in! Carefully slide the screen assembly away from the back cover.
  4. LG G Pad 7.0 Battery Replacement, A Look on the Inside: stap 4, afbeelding 1 van 1
    • Here's the inside of the tablet. Pretty straight forward, nothing to spectacular.
  5. LG G Pad 7.0 Battery Replacement: stap 5, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Koop
    • Grab your * Tweezers, the best tweezers you can get!
  6. LG G Pad 7.0 Battery Replacement, Charging Port Flex: stap 6, afbeelding 1 van 1
    Koop
    • Carefully pry up the charging port connection from the bottom left with your Tweezers.
  7. LG G Pad 7.0 Battery Replacement, Battery Connection: stap 7, afbeelding 1 van 1
    • Carefully lift the battery connector.
  8. LG G Pad 7.0 Battery Replacement, Removing the Battery: stap 8, afbeelding 1 van 1
    iSesamo Opening Tool
    $9.99
    Koop
  9. LG G Pad 7.0 Battery Replacement, Disposal of old Battery: stap 9, afbeelding 1 van 1
    • After removing the faulty/dead battery, make sure you properly dispose it.
  10. LG G Pad 7.0 Battery Replacement, Don't Forget!: stap 10, afbeelding 1 van 2 LG G Pad 7.0 Battery Replacement, Don't Forget!: stap 10, afbeelding 2 van 2
    • After reconnecting the new battery and charging flex cable, make sure you put the headphone jack back into place.
    • There you go! A quick battery replacement on your LG G-Pad.
Conclusie
GadgetERService
1.650 Reputatie
2 handleidingen geschreven
Minnesota Repair Techs Lid van Minnesota Repair Techs
Community
3 Leden
2 opmerkingen
Big thanks to the Author for this, I used it on my v410, worked perfect !
Max Haxster - Antwoord
My G pad 7.0 wont turn on. Do I have to do some kind or re-boot or restart it? Cause one time when I changed mi iPhone 5c's battery I had to restart it the phone.
Mario Escobar - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 5
Altijd: 2,681
