Ga door naar hoofdinhoud
Inleiding
This guide will show you step by step how to access the internals of a LG G Pad 7.0(LG-V410) and replace the battery.
  1. Here it is - LG G-Pad 7.0. Let's dive right in!
    • Here it is - LG G-Pad 7.0. Let's dive right in!
  2. First things first, use the handy pick iFixit sells on their online store. Carefully pry the frame apart in between the screen assembly an back cover. Be extremely careful, you don't want to damage the motherboard.. First things first, use the handy pick iFixit sells on their online store. Carefully pry the frame apart in between the screen assembly an back cover. Be extremely careful, you don't want to damage the motherboard..
    • First things first, use the handy pick iFixit sells on their online store. Carefully pry the frame apart in between the screen assembly an back cover. Be extremely careful, you don't want to damage the motherboard..
  3. Vuala!  We're in! Carefully slide the screen assembly away from the back cover.
    • Vuala! We're in! Carefully slide the screen assembly away from the back cover.
  4. Here's the inside of the tablet. Pretty straight forward, nothing to spectacular.
    • Here's the inside of the tablet. Pretty straight forward, nothing to spectacular.
  5. Android Fix Kits
    Slechts één reparatie scheidt jou van een nieuw scherm of een nieuwe batterij.
    Nu winkelen
    Android Fix Kits
    Nu winkelen
    • Grab your * Tweezers, the best tweezers you can get!
    • Carefully pry up the charging port connection from the bottom left with your Tweezers.
  6. Carefully lift the battery connector.
    • Carefully lift the battery connector.
  7. After removing the faulty/dead battery, make sure you properly dispose it.
    • After removing the faulty/dead battery, make sure you properly dispose it.
  8. After reconnecting the new battery and charging flex cable, make sure you put the headphone jack back into place. After reconnecting the new battery and charging flex cable, make sure you put the headphone jack back into place.
    • After reconnecting the new battery and charging flex cable, make sure you put the headphone jack back into place.
    • There you go! A quick battery replacement on your LG G-Pad.
Conclusie
GadgetERService
1.604 Reputatie
2 handleidingen geschreven
Minnesota Repair Techs Lid van Minnesota Repair Techs
Community
3 Leden
Big thanks to the Author for this, I used it on my v410, worked perfect !
Max Haxster - Antwoord
My G pad 7.0 wont turn on. Do I have to do some kind or re-boot or restart it? Cause one time when I changed mi iPhone 5c's battery I had to restart it the phone.
Mario Escobar - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 15
Altijd: 1,909
