Inleiding
Follow this guide if you need to replace the screen of your LG Fortune. In this guide you will be removing the microphone from the screen, so that you can get the screen by itself.
Wat je nodig hebt
Use the slit on the bottom right side of the phone to open the back cover of your phone.
Slowly pry the back cover off the phone starting from the bottom up to the top.
Using a PH000 screwdriver, remove the ten 4mm screws on the back panelling.
Remove the back panelling from the device with your fingers or a spudger.
Work slowly side to side to release this back casing and expose the motherboard.
Use the spudger to pry off the motherboard from the rest of the device on the top left corner down to the bottom right corner
Unplug the camera from the phone using a metal spudger to get underneath the tape and remove the camera.
You will remove the microphone from underside of the screen.
Once the mic is off, the screen is by itself and ready to be replaced.
6 andere personen hebben deze handleiding voltooid.
