Ga door naar hoofdinhoud
LG Flare Microphone Replacement
Wat je nodig hebt
  1. LG Flare Microphone Replacement, Microphone: stap 1, afbeelding 1 van 2 LG Flare Microphone Replacement, Microphone: stap 1, afbeelding 2 van 2
    • Remove the back cover by pressing on the top middle raised lines of the back cover and sliding the cover off.
  2. LG Flare Microphone Replacement: stap 2, afbeelding 1 van 1
    • Remove the battery by popping the top out and removing the battery.
  3. LG Flare Microphone Replacement: stap 3, afbeelding 1 van 1
    • Use appropriately sized Philips-head screwdriver to remove the six small screws on the back of the phone under the battery.
  4. LG Flare Microphone Replacement: stap 4, afbeelding 1 van 1
    • Use an opening tool to pop the back panel apart around the edges, and then pry the whole piece off.
  5. LG Flare Microphone Replacement: stap 5, afbeelding 1 van 1
    • Use an opening tool to separate the tabs on the green circuit board from the front body of the phone.
  6. LG Flare Microphone Replacement: stap 6, afbeelding 1 van 1
    • Use an opening tool to pop the orange connecting strip off of the circuit board.
  7. LG Flare Microphone Replacement: stap 7, afbeelding 1 van 1
    • Un-clip the 2 metal clips on one side of the circuit board.
  8. LG Flare Microphone Replacement: stap 8, afbeelding 1 van 2 LG Flare Microphone Replacement: stap 8, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    • Using tweezers and wedge, remove silver piece from green circuit board.
  9. LG Flare Microphone Replacement: stap 9, afbeelding 1 van 1
    • Remove the microphone (rip soldering).
  10. LG Flare Microphone Replacement: stap 10, afbeelding 1 van 1
    • Solder new microphone in place OR buy replacement circuit board from www.ifixit.com and replace.
Conclusie
Kelsey Hanna
1 Reputatie
1 Handleiding geschreven
Ohio State, Team 1-3, Garvin Fall 2015 Lid van Ohio State, Team 1-3, Garvin Fall 2015
OSU-GARVIN-F15S1G3
4 Leden
4 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 8
Altijd: 314
