Ga door naar hoofdinhoud
LG EnV Touch VX11000 Screen Assembly Replacement
Wat je nodig hebt
  1. LG EnV Touch VX11000 Screen Assembly Replacement, Battery: stap 1, afbeelding 1 van 1
    • Turn the phone off.
    • Flip it over so the front screen is facing down.
  2. LG EnV Touch VX11000 Screen Assembly Replacement: stap 2, afbeelding 1 van 1
    • Slide the release latch down and toward you while lifting up on the left side of the battery cover.
  3. LG EnV Touch VX11000 Screen Assembly Replacement: stap 3, afbeelding 1 van 2 LG EnV Touch VX11000 Screen Assembly Replacement: stap 3, afbeelding 2 van 2
    • Lift the edge of the battery to remove it.
  4. LG EnV Touch VX11000 Screen Assembly Replacement, Volume and Camera Buttons: stap 4, afbeelding 1 van 2 LG EnV Touch VX11000 Screen Assembly Replacement, Volume and Camera Buttons: stap 4, afbeelding 2 van 2
    • Locate the three screw covers on the back of the phone. Using your fingernail (or a spudger, pry off screw covers.
    • Using a Phillips #000 Screwdriver, remove the 1.5mm #000 Phillips screws that were under the screw covers.
  5. LG EnV Touch VX11000 Screen Assembly Replacement: stap 5, afbeelding 1 van 1
    • Locate the two inner 1.5mm #000 Phillips screws and remove them using a Phillips #000 screwdriver.
  6. LG EnV Touch VX11000 Screen Assembly Replacement: stap 6, afbeelding 1 van 2 LG EnV Touch VX11000 Screen Assembly Replacement: stap 6, afbeelding 2 van 2
    • Use a plastic opening tool or your fingernail to pry off the back case.
    • The camera and volume keys will fall off.
  7. LG EnV Touch VX11000 Screen Assembly Replacement, Screen Assembly: stap 7, afbeelding 1 van 3 LG EnV Touch VX11000 Screen Assembly Replacement, Screen Assembly: stap 7, afbeelding 2 van 3 LG EnV Touch VX11000 Screen Assembly Replacement, Screen Assembly: stap 7, afbeelding 3 van 3
    • Open the phone at a 90 degree angle. This needs to be done in order to reach the screws.
    • Locate the two 1.5mm #000 Phillips screws on the outside of each hinge.
    • Remove the two 1.5mm #000 Phillips screws with a Phillips #000 screwdriver.
  8. LG EnV Touch VX11000 Screen Assembly Replacement: stap 8, afbeelding 1 van 2 LG EnV Touch VX11000 Screen Assembly Replacement: stap 8, afbeelding 2 van 2
    • Pry off the two screw covers on the inside screen, using a spudger or your fingernail.
    • Remove the two 1.5mm #000 Phillips screws that were under the screw covers using the Phillips #000 screwdriver.
  9. LG EnV Touch VX11000 Screen Assembly Replacement: stap 9, afbeelding 1 van 2 LG EnV Touch VX11000 Screen Assembly Replacement: stap 9, afbeelding 2 van 2
    • Pry off the front frame using your fingernail.
    • The frame should still be connected to the rest of the phone by the orange tab.
  10. LG EnV Touch VX11000 Screen Assembly Replacement: stap 10, afbeelding 1 van 1
    • Remove the four 1.5mm #000 Phillips screws at each of the corners of the phone, using the Phillips #000 screwdriver.
  11. LG EnV Touch VX11000 Screen Assembly Replacement: stap 11, afbeelding 1 van 3 LG EnV Touch VX11000 Screen Assembly Replacement: stap 11, afbeelding 2 van 3 LG EnV Touch VX11000 Screen Assembly Replacement: stap 11, afbeelding 3 van 3
    • Peel off the gold tape.
    • Gently pry up the metal frame with your fingers so that the screen can be removed.
  12. LG EnV Touch VX11000 Screen Assembly Replacement: stap 12, afbeelding 1 van 2 LG EnV Touch VX11000 Screen Assembly Replacement: stap 12, afbeelding 2 van 2
    • Unplug the connector from the screen.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Rachel Smith
593 Reputatie
5 handleidingen geschreven
Cal Poly, Team 13-2, Forte Fall 2013 Lid van Cal Poly, Team 13-2, Forte Fall 2013
CPSU-FORTE-F13S13G2
4 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 4
Altijd: 1,123
