Inleiding
If the keyboard on your LG EnV Touch VX11000 is unresponsive or malfunctioning, you may need to replace it. This guide will show you how to replace the keyboard on an LG EnV Touch VX11000.
Wat je nodig hebt
Locate the three screw covers on the back of the phone. Using your fingernail (or a spudger, pry off screw covers.
Using a Phillips #000 Screwdriver, remove the 1.5mm #000 Phillips screws that were under the screw covers.
Use your hands to open the phone, separating the keyboard frame from the screen.
Using your thumbs, gently separate the motherboard from the frame, and the keyboard will fall out.
Één andere persoon heeft deze handleiding voltooid.
