Ga door naar hoofdinhoud
LG EnV Touch VX11000 Keyboard Replacement
Wat je nodig hebt
  1. LG EnV Touch VX11000 Keyboard Replacement, Battery: stap 1, afbeelding 1 van 1
    • Turn the phone off.
    • Flip it over so the front screen is facing down.
  2. LG EnV Touch VX11000 Keyboard Replacement: stap 2, afbeelding 1 van 1
    • Slide the release latch down and toward you while lifting up on the left side of the battery cover.
  3. LG EnV Touch VX11000 Keyboard Replacement: stap 3, afbeelding 1 van 2 LG EnV Touch VX11000 Keyboard Replacement: stap 3, afbeelding 2 van 2
    • Lift the edge of the battery to remove it.
  4. LG EnV Touch VX11000 Keyboard Replacement, Volume and Camera Buttons: stap 4, afbeelding 1 van 2 LG EnV Touch VX11000 Keyboard Replacement, Volume and Camera Buttons: stap 4, afbeelding 2 van 2
    • Locate the three screw covers on the back of the phone. Using your fingernail (or a spudger, pry off screw covers.
    • Using a Phillips #000 Screwdriver, remove the 1.5mm #000 Phillips screws that were under the screw covers.
  5. LG EnV Touch VX11000 Keyboard Replacement: stap 5, afbeelding 1 van 1
    • Locate the two inner 1.5mm #000 Phillips screws and remove them using a Phillips #000 screwdriver.
  6. LG EnV Touch VX11000 Keyboard Replacement: stap 6, afbeelding 1 van 2 LG EnV Touch VX11000 Keyboard Replacement: stap 6, afbeelding 2 van 2
    • Use a plastic opening tool or your fingernail to pry off the back case.
    • The camera and volume keys will fall off.
  7. LG EnV Touch VX11000 Keyboard Replacement, Keyboard: stap 7, afbeelding 1 van 1
    • Use your hands to open the phone, separating the keyboard frame from the screen.
    • Using your thumbs, gently separate the motherboard from the frame, and the keyboard will fall out.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Rachel Smith
593 Reputatie
5 handleidingen geschreven
Cal Poly, Team 13-2, Forte Fall 2013 Lid van Cal Poly, Team 13-2, Forte Fall 2013
CPSU-FORTE-F13S13G2
4 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 10
Altijd: 432
