Ga door naar hoofdinhoud
Inleiding
Use this guide to install a new digitizer in your LG Dare.
Onderdelen
Geen onderdelen opgegeven.
  1. Remove the back cover by firmly pressing against the raised lip on the back panel. Slide the cover towards the top of the phone. Remove the back cover by firmly pressing against the raised lip on the back panel. Slide the cover towards the top of the phone.
    • Remove the back cover by firmly pressing against the raised lip on the back panel. Slide the cover towards the top of the phone.
  2. Remove the battery by placing your fingernail or a opening tool in the recessed edge and lift the battery out. Remove the battery by placing your fingernail or a opening tool in the recessed edge and lift the battery out. Remove the battery by placing your fingernail or a opening tool in the recessed edge and lift the battery out.
    • Remove the battery by placing your fingernail or a opening tool in the recessed edge and lift the battery out.
  3. Use the #00 screwdriver to remove the six 4mm phillips screws located around the edges of the phone. Use the #00 screwdriver to remove the six 4mm phillips screws located around the edges of the phone.
    • Use the #00 screwdriver to remove the six 4mm phillips screws located around the edges of the phone.
  4. Lift the back plastic cover off by moving the opening tool around the edges of the phone. Wedging the opening tool in several places on the bottom of the phone will help release small tabs that hold the back to the front frame. The side buttons may fall out when removing the back plastic.
    • Lift the back plastic cover off by moving the opening tool around the edges of the phone.
    • Wedging the opening tool in several places on the bottom of the phone will help release small tabs that hold the back to the front frame.
    • The side buttons may fall out when removing the back plastic.
  5. Pull off the back plastic panel. Remove the buttons from the edge of the frame. The buttons are [lock], [volume control], [speaker], and [camera]. Remove the buttons from the edge of the frame. The buttons are [lock], [volume control], [speaker], and [camera].
    • Pull off the back plastic panel.
    • Remove the buttons from the edge of the frame. The buttons are [lock], [volume control], [speaker], and [camera].
  6. Disconnect the three ribbon connectors from the motherboard.
    • Disconnect the three ribbon connectors from the motherboard.
  7. Remove the LED. Remove the camera connector. Remove the camera sensor from the logic board. Squeeze the sides of the camera sensor firmly and pull straight up.
    • Remove the LED.
    • Remove the camera connector.
    • Remove the camera sensor from the logic board. Squeeze the sides of the camera sensor firmly and pull straight up.
  8. Open the USB port cover.
    • Open the USB port cover.
  9. iPhone X Fix Kits
    Warranty up? No worries, we’ve got the fix.
    Nu winkelen
    iPhone X Fix Kits
    Nu winkelen
  10. Use the opening tool to lift up the green logic board in all areas and remove it. The logic board may require some force to remove because it is taped to the plastic frame. When removing the logic board, be careful not to tear any of the ribbon cables or side buttons.
    • Use the opening tool to lift up the green logic board in all areas and remove it.
    • The logic board may require some force to remove because it is taped to the plastic frame.
    • When removing the logic board, be careful not to tear any of the ribbon cables or side buttons.
  11. Peel off the gold and green tape near the bottom of the phone. Peel off the blue tape covering the speaker connector. Peel off the gold tape to the left of the earpiece speaker.
    • Peel off the gold and green tape near the bottom of the phone.
    • Peel off the blue tape covering the speaker connector.
    • Peel off the gold tape to the left of the earpiece speaker.
    • It is unnecessary to remove the blue and gold tape from the device if the speaker is not being removed.
  12. Lift up the orange ribbon cable in the bottom left corner of the device. Peel off the small piece of gold tape underneath the orange component back.
    • Lift up the orange ribbon cable in the bottom left corner of the device.
    • Peel off the small piece of gold tape underneath the orange component back.
  13. Undo the  clips that attach the black plastic strip to the frame of the phone. Pry the plastic strip away from the phone,  using an opening tool, until it detaches.
    • Undo the clips that attach the black plastic strip to the frame of the phone.
    • Pry the plastic strip away from the phone, using an opening tool, until it detaches.
  14. Pry the button panel from the device, starting where the screen and panel connect, until the panel detaches. Pry the button panel from the device, starting where the screen and panel connect, until the panel detaches.
    • Pry the button panel from the device, starting where the screen and panel connect, until the panel detaches.
  15. Rotate the phone upside down with the back facing you. Using your finger to hold the bottom connector in place, use the opening tool to remove the top connector.
    • Rotate the phone upside down with the back facing you.
    • Using your finger to hold the bottom connector in place, use the opening tool to remove the top connector.
  16. Using the opening tool, pry the frame from the device, starting at the open edges at the bottom of the device, and working your way around. Do not detach the frame yet. Do not detach the frame yet.
    • Using the opening tool, pry the frame from the device, starting at the open edges at the bottom of the device, and working your way around.
    • Do not detach the frame yet.
  17. Gently separate the top of the frame from the back of the device, without completely detaching at the bottom, as shown in the third picture. Gently separate the top of the frame from the back of the device, without completely detaching at the bottom, as shown in the third picture. Gently separate the top of the frame from the back of the device, without completely detaching at the bottom, as shown in the third picture.
    • Gently separate the top of the frame from the back of the device, without completely detaching at the bottom, as shown in the third picture.
  18. Remove both connectors from the frame. Fold back the L-shaped connector and  slide the second connector through the hole in the metal frame. Remove the frame from the plastic panel.
    • Remove both connectors from the frame. Fold back the L-shaped connector and slide the second connector through the hole in the metal frame.
    • Remove the frame from the plastic panel.
    • The next two steps are for earpiece removal only.
  19. Using the opening tool, pry the orange connector pad that is securing the earpiece to the frame, away from the device, until it detaches. It may be necessary to apply more force to remove the pad because it is taped to the frame.
    • Using the opening tool, pry the orange connector pad that is securing the earpiece to the frame, away from the device, until it detaches.
    • It may be necessary to apply more force to remove the pad because it is taped to the frame.
  20. Pry the rest of the orange connector pad --on the opposite side of the device-- away from the frame, and carefully remove the entire earpiece. Pry the rest of the orange connector pad --on the opposite side of the device-- away from the frame, and carefully remove the entire earpiece.
    • Pry the rest of the orange connector pad --on the opposite side of the device-- away from the frame, and carefully remove the entire earpiece.
  21. Lift all four corners of the screen. Being too aggressive could damage the screen.
    • Lift all four corners of the screen.
    • Being too aggressive could damage the screen.
  22. Remove the screen from the digitizer. Remove the screen from the digitizer.
    • Remove the screen from the digitizer.
  23. Using the opening tool, carefully pry the digitizer (the black-rimmed piece) away from the silver frame. Remove the digitizer carefully without breaking the connector. Be careful when removing the digitizer because it is glued to the front panel. It may be necessary to apply more force or use a blow dryer to loosen the glue.
    • Using the opening tool, carefully pry the digitizer (the black-rimmed piece) away from the silver frame.
    • Remove the digitizer carefully without breaking the connector.
    • Be careful when removing the digitizer because it is glued to the front panel. It may be necessary to apply more force or use a blow dryer to loosen the glue.
  24. Carefully remove the digitizer connector from the plastic frame. There is a slot that the connector slides through.
    • Carefully remove the digitizer connector from the plastic frame. There is a slot that the connector slides through.
Conclusie
To re-assemble your device, follow these instructions in reverse order.
Haoyan Huang
112 Reputatie
4 handleidingen geschreven
Cal Poly, Team 9-4, Regan Winter 2012 Lid van Cal Poly, Team 9-4, Regan Winter 2012
CPSU-REGAN-W12S9G4
5 Leden
10 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 0
Afgelopen 30 Dagen: 1
Altijd: 4,883
