Ga door naar hoofdinhoud
LG Cosmos Side Case Replacement
Wat je nodig hebt
  1. LG Cosmos Side Case Replacement, Battery: stap 1, afbeelding 1 van 1
    • Apply an upward force to slide the back cover off.
  2. LG Cosmos Side Case Replacement: stap 2, afbeelding 1 van 1
    • Use your finger to push down on the top of the battery and pull it out.
  3. LG Cosmos Side Case Replacement, Rear Case: stap 3, afbeelding 1 van 1
    • Remove the five 3.0mm Phillips #000 screws along the edge of the rear case.
  4. LG Cosmos Side Case Replacement: stap 4, afbeelding 1 van 1
    • Use a plastic opening tool to pry the rear case loose.
  5. LG Cosmos Side Case Replacement: stap 5, afbeelding 1 van 1
    • Once the rear case is loose, lift it from the rest of the phone.
  6. LG Cosmos Side Case Replacement, Motherboard: stap 6, afbeelding 1 van 1
    • Remove the two 2.9 mm Phillips #000 screws that are slightly off-centered to the right.
  7. LG Cosmos Side Case Replacement: stap 7, afbeelding 1 van 1
    • Use the plastic opening tool to pry the motherboard loose.
  8. LG Cosmos Side Case Replacement: stap 8, afbeelding 1 van 1
    • Hold the motherboard from the top and bottom and slowly lift the motherboard until you feel a pull.
    • The flex cable is attached at the bottom of the motherboard and can be damaged if too much lifting force is applied.
  9. LG Cosmos Side Case Replacement: stap 9, afbeelding 1 van 1
    • Once the motherboard is lifted , rotate the motherboard up 90 degrees to the right.
  10. LG Cosmos Side Case Replacement: stap 10, afbeelding 1 van 1
    • Use your finger to pull the flex cable out from its connector.
  11. LG Cosmos Side Case Replacement: stap 11, afbeelding 1 van 1
    • Pull the motherboard away from the rest of the phone.
  12. LG Cosmos Side Case Replacement, Silicon Keypad: stap 12, afbeelding 1 van 1
    • Lift the silicon keypad away from the rest of the phone.
  13. LG Cosmos Side Case Replacement, Side Case: stap 13, afbeelding 1 van 1
    • Remove the four 2.0mm Phillips #000 screws on the golden squares.
  14. LG Cosmos Side Case Replacement: stap 14, afbeelding 1 van 1
    • Slowly lift the side case away from the rest of the phone.
    • The flex cable can be torn if it is caught on the frame of the side case.
Conclusie
Johnny Phane
91 Reputatie
5 handleidingen geschreven
Cal Poly, Team 13-63, Johann Spring 2013 Lid van Cal Poly, Team 13-63, Johann Spring 2013
CPSU-JOHANN-S13S13G63
3 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 7
Altijd: 1,046
