Inleiding
The steps to this process straightforward and mostly involve removing screws.
Gereedschap
Onderdelen
Geen onderdelen opgegeven.
Insert the plastic opener into the slot at the top of the device.
Apply gentle pressure with the plastic tool to pop the back case off.
Use a screwdriver and corresponding bit to remove the six 2mm screws that are located along the edge of the rear case. Set the screws aside.
Use a screwdriver and corresponding bit to remove the two 3mm screws that attach the motherboard to the front case. Set the screws aside
Bijna klaar!
Conclusie
