Ga door naar hoofdinhoud
LG Cosmos 2 Front Keyboard Replacement
Wat je nodig hebt
  1. LG Cosmos 2 Front Keyboard Replacement, Battery: stap 1, afbeelding 1 van 3 LG Cosmos 2 Front Keyboard Replacement, Battery: stap 1, afbeelding 2 van 3 LG Cosmos 2 Front Keyboard Replacement, Battery: stap 1, afbeelding 3 van 3
    • Insert the plastic opener into the slot at the top of the device.
    • Apply gentle pressure with the plastic tool to pop the back case off.
  2. LG Cosmos 2 Front Keyboard Replacement: stap 2, afbeelding 1 van 3 LG Cosmos 2 Front Keyboard Replacement: stap 2, afbeelding 2 van 3 LG Cosmos 2 Front Keyboard Replacement: stap 2, afbeelding 3 van 3
    • Use the plastic opener to lift, and remove, the device battery.
  3. LG Cosmos 2 Front Keyboard Replacement, Rear Case: stap 3, afbeelding 1 van 1
    • Use a screwdriver and corresponding bit to remove the six 2mm screws that are located along the edge of the rear case. Set the screws aside.
  4. LG Cosmos 2 Front Keyboard Replacement: stap 4, afbeelding 1 van 3 LG Cosmos 2 Front Keyboard Replacement: stap 4, afbeelding 2 van 3 LG Cosmos 2 Front Keyboard Replacement: stap 4, afbeelding 3 van 3
    • Use the plastic opener to pry the rear case loose.
    • This can be difficult. You will need to pry around the entire edge of the rear case, not just in one place.
  5. LG Cosmos 2 Front Keyboard Replacement, Motherboard: stap 5, afbeelding 1 van 1
    • Use a screwdriver and corresponding bit to remove the two 3mm screws that attach the motherboard to the front case. Set the screws aside
  6. LG Cosmos 2 Front Keyboard Replacement: stap 6, afbeelding 1 van 1
    • Rotate the phone 180 degrees and use the plastic opener to lift the metal piece that covers the ribbon cable.
  7. LG Cosmos 2 Front Keyboard Replacement: stap 7, afbeelding 1 van 2 LG Cosmos 2 Front Keyboard Replacement: stap 7, afbeelding 2 van 2
    • Use the plastic opener to disconnect the ribbon cable.
  8. LG Cosmos 2 Front Keyboard Replacement: stap 8, afbeelding 1 van 2 LG Cosmos 2 Front Keyboard Replacement: stap 8, afbeelding 2 van 2
    • Use tweezers to disconnect the two cables that attach the motherboard to the case.
    • Note: Pull on the cables gently to prevent damage for future use.
  9. LG Cosmos 2 Front Keyboard Replacement: stap 9, afbeelding 1 van 1
    • Remove the motherboard from the front case.
  10. LG Cosmos 2 Front Keyboard Replacement, Option Buttons: stap 10, afbeelding 1 van 1
    • Use a screwdriver and corresponding bit to remove the four 1mm screws. Set the screws aside.
  11. LG Cosmos 2 Front Keyboard Replacement: stap 11, afbeelding 1 van 2 LG Cosmos 2 Front Keyboard Replacement: stap 11, afbeelding 2 van 2
    • Pull the ribbon cable through the slit in the keyboard case to separate it from the sliding mechanism.
  12. LG Cosmos 2 Front Keyboard Replacement: stap 12, afbeelding 1 van 1
    • Use a screwdriver and corresponding bit to remove the four 3mm screws. Set the screws aside.
    • Note: Two of the screws may be hidden underneath a black rubber film. Pull off this film if necessary.
  13. LG Cosmos 2 Front Keyboard Replacement: stap 13, afbeelding 1 van 2 LG Cosmos 2 Front Keyboard Replacement: stap 13, afbeelding 2 van 2
    • Use the plastic opener to pry open the front of the phone.
    • Slip the ribbon cable through the slit to fully separate the two pieces.
  14. LG Cosmos 2 Front Keyboard Replacement: stap 14, afbeelding 1 van 1
    • Use a screwdriver and corresponding bit to remove the two 1mm screws. Set the screws aside.
  15. LG Cosmos 2 Front Keyboard Replacement: stap 15, afbeelding 1 van 1
    • Detach the ribbon cable with the plastic opener.
  16. LG Cosmos 2 Front Keyboard Replacement: stap 16, afbeelding 1 van 3 LG Cosmos 2 Front Keyboard Replacement: stap 16, afbeelding 2 van 3 LG Cosmos 2 Front Keyboard Replacement: stap 16, afbeelding 3 van 3
    • Use the spudger to pry the metal piece loose.
    • Remove the metal piece along with the two ribbon cables.
  17. LG Cosmos 2 Front Keyboard Replacement: stap 17, afbeelding 1 van 1
    • Flip the front of the phone over and the old option buttons will fall out.
    • Insert new option buttons.
  18. LG Cosmos 2 Front Keyboard Replacement, Front Keyboard: stap 18, afbeelding 1 van 2 LG Cosmos 2 Front Keyboard Replacement, Front Keyboard: stap 18, afbeelding 2 van 2
    • Use a tool to pry open the LCD display. Remove the display and the motherboard-looking device that it's connected to.
  19. LG Cosmos 2 Front Keyboard Replacement: stap 19, afbeelding 1 van 1
    • Rotate and remove the keypad from the front case.
Conclusie
Nick White
851 Reputatie
8 handleidingen geschreven
Clemson, Team 13-1, Benson Fall 2013 Lid van Clemson, Team 13-1, Benson Fall 2013
CLEM-BENSON-F13S13G1
3 Leden
16 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 669
