Ga door naar hoofdinhoud
LG CineBeam Wi-Fi and Bluetooth Card Replacement
Wat je nodig hebt
  1. LG CineBeam Wi-Fi and Bluetooth Card Replacement, Bottom Plate: stap 1, afbeelding 1 van 1
    • Remove three 6 mm screws on the bottom plate with a Phillips #00 screwdriver.
  2. LG CineBeam Wi-Fi and Bluetooth Card Replacement: stap 2, afbeelding 1 van 3 LG CineBeam Wi-Fi and Bluetooth Card Replacement: stap 2, afbeelding 2 van 3 LG CineBeam Wi-Fi and Bluetooth Card Replacement: stap 2, afbeelding 3 van 3
    • Using an iFixit opening tool, pry the bottom plate off of the device and remove it fully.
  3. LG CineBeam Wi-Fi and Bluetooth Card Replacement, Motherboard: stap 3, afbeelding 1 van 3 LG CineBeam Wi-Fi and Bluetooth Card Replacement, Motherboard: stap 3, afbeelding 2 van 3 LG CineBeam Wi-Fi and Bluetooth Card Replacement, Motherboard: stap 3, afbeelding 3 van 3
    • Using an iFixit opening tool, press down the lever on the top of the minilock connector for the speaker and pull the plug out gently.
    • Repeat this process to remove the WiFi/Bluetooth card connector.
    • Remove the battery connector.
    • Remove the fan connectors.
  4. LG CineBeam Wi-Fi and Bluetooth Card Replacement: stap 4, afbeelding 1 van 2 LG CineBeam Wi-Fi and Bluetooth Card Replacement: stap 4, afbeelding 2 van 2
    • Using an iFixit opening tool, pry up the black plastic tabs on the back of the power button/joystick board cable.
    • Gently pull the ribbon cable out of the socket.
    • Repeat this process for the two display cables.
  5. LG CineBeam Wi-Fi and Bluetooth Card Replacement: stap 5, afbeelding 1 van 3 LG CineBeam Wi-Fi and Bluetooth Card Replacement: stap 5, afbeelding 2 van 3 LG CineBeam Wi-Fi and Bluetooth Card Replacement: stap 5, afbeelding 3 van 3
    • Lift the motherboard out of the casing.
  6. LG CineBeam Wi-Fi and Bluetooth Card Replacement, Speaker: stap 6, afbeelding 1 van 2 LG CineBeam Wi-Fi and Bluetooth Card Replacement, Speaker: stap 6, afbeelding 2 van 2
    • Use your fingers to lift the speaker from the casing.
  7. LG CineBeam Wi-Fi and Bluetooth Card Replacement, Battery: stap 7, afbeelding 1 van 3 LG CineBeam Wi-Fi and Bluetooth Card Replacement, Battery: stap 7, afbeelding 2 van 3 LG CineBeam Wi-Fi and Bluetooth Card Replacement, Battery: stap 7, afbeelding 3 van 3
    • Turn the device over so the power button is facing up.
    • Using an iFixit opening tool, pry open the top of the plastic casing and remove it completely.
  8. LG CineBeam Wi-Fi and Bluetooth Card Replacement: stap 8, afbeelding 1 van 3 LG CineBeam Wi-Fi and Bluetooth Card Replacement: stap 8, afbeelding 2 van 3 LG CineBeam Wi-Fi and Bluetooth Card Replacement: stap 8, afbeelding 3 van 3
    • Using an iFixit opening tool, remove the battery.
  9. LG CineBeam Wi-Fi and Bluetooth Card Replacement, Wi-Fi and Bluetooth Card: stap 9, afbeelding 1 van 3 LG CineBeam Wi-Fi and Bluetooth Card Replacement, Wi-Fi and Bluetooth Card: stap 9, afbeelding 2 van 3 LG CineBeam Wi-Fi and Bluetooth Card Replacement, Wi-Fi and Bluetooth Card: stap 9, afbeelding 3 van 3
    • Using an iFixit opening tool, move the plastic clip on the right side of the board out of the way.
    • Using an iFixit opening tool, pry the Wi-Fi and Bluetooth card out of its socket.
Conclusie
John Dalton
393 Reputatie
4 handleidingen geschreven
UMass Dartmouth, Team 1-5, Botvin Spring 2022 Lid van UMass Dartmouth, Team 1-5, Botvin Spring 2022
UMASSD-BOTVIN-S22S1G5
3 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 10
Altijd: 178
