Ga door naar hoofdinhoud
LG Chocolate LCD Screen Replacement
Wat je nodig hebt
  1. LG Chocolate LCD Screen Replacement, Battery: stap 1, afbeelding 1 van 2 LG Chocolate LCD Screen Replacement, Battery: stap 1, afbeelding 2 van 2
    • Find a sliding button on the lower back side of the device and with your finger, slide it to the left firmly.
    • The battery should pop out fairly easily. If not, slide the button further or grab and pull it while sliding the button.
  2. LG Chocolate LCD Screen Replacement, Back Cover: stap 2, afbeelding 1 van 1
    • You will need to use a Phillips #00 screwdriver.
    • Remove the four screws located at the corners beneath the battery.
    • Detach the back case from the phone.
  3. LG Chocolate LCD Screen Replacement: stap 3, afbeelding 1 van 3 LG Chocolate LCD Screen Replacement: stap 3, afbeelding 2 van 3 LG Chocolate LCD Screen Replacement: stap 3, afbeelding 3 van 3
    • Take the case off by using a plastic opening tool.
    • Continue using the plastic opening tool around the sides of the device.
    • Unhook the eight tabs securing the back cover to the rest of the phone as seen in the second photo.
    • The back speaker will be connected to the motherboard.
    • This must be disconnected in order to remove the case
  4. LG Chocolate LCD Screen Replacement, Sliding Front: stap 4, afbeelding 1 van 1
    • Unscrew the 4 Phillips 00 screws that connect the two halves of the phone together.
  5. LG Chocolate LCD Screen Replacement: stap 5, afbeelding 1 van 2 LG Chocolate LCD Screen Replacement: stap 5, afbeelding 2 van 2
    • Between the two halves is a ribbon. Use a plastic opening tool to flip up the lock and disconnect it.
  6. LG Chocolate LCD Screen Replacement: stap 6, afbeelding 1 van 2 LG Chocolate LCD Screen Replacement: stap 6, afbeelding 2 van 2
    • Pry off the plastic tabs that cover two screws, as shown in the first picture.
    • Then, remove the 6 Phillips 00 screws from the back of the case, as shown in the second picture.
  7. LG Chocolate LCD Screen Replacement: stap 7, afbeelding 1 van 1
    • Pry off the back cover from the front of the case using a plastic opening tool.
  8. LG Chocolate LCD Screen Replacement, LCD Board: stap 8, afbeelding 1 van 3 LG Chocolate LCD Screen Replacement, LCD Board: stap 8, afbeelding 2 van 3 LG Chocolate LCD Screen Replacement, LCD Board: stap 8, afbeelding 3 van 3
    • Pry the front speaker and wireless receiver out of the front case using a spudger.
    • They may be taped into the case, so don't be afraid to pry hard.
  9. LG Chocolate LCD Screen Replacement: stap 9, afbeelding 1 van 2 LG Chocolate LCD Screen Replacement: stap 9, afbeelding 2 van 2
    • Starting with the side that has the speaker and receiver, carefully lift the LCD Board out of the case.
  10. LG Chocolate LCD Screen Replacement: stap 10, afbeelding 1 van 1
    • Unhook the ribbon cable using that flat side of a spudger.
  11. LG Chocolate LCD Screen Replacement: stap 11, afbeelding 1 van 1
    • Next, carefully remove the tape from the LCD board.
  12. LG Chocolate LCD Screen Replacement: stap 12, afbeelding 1 van 2 LG Chocolate LCD Screen Replacement: stap 12, afbeelding 2 van 2
    • Finally, flip up the black switch to unhook the LCD screen from the LCD board using a spudger.
    • The LCD Board in now accessible.
  13. LG Chocolate LCD Screen Replacement, LCD Screen: stap 13, afbeelding 1 van 1
    • The LCD screen is no longer connected to the LCD board.
Conclusie
Charles Yoon
64 Reputatie
2 handleidingen geschreven
Cal Poly, Team 19-46, Regan Winter 2013 Lid van Cal Poly, Team 19-46, Regan Winter 2013
CPSU-REGAN-W13S19G46
4 Leden
22 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 15
Altijd: 851
