Ga door naar hoofdinhoud
LG Chocolate 3 Rear Case Replacement
Wat je nodig hebt
  1. LG Chocolate 3 Rear Case Replacement, Battery: stap 1, afbeelding 1 van 1
    • Turn the phone off before starting the replacement process.
    • Place the phone face down.
    • Press your finger down on the indentation and slide the back plate off.
  2. LG Chocolate 3 Rear Case Replacement: stap 2, afbeelding 1 van 3 LG Chocolate 3 Rear Case Replacement: stap 2, afbeelding 2 van 3 LG Chocolate 3 Rear Case Replacement: stap 2, afbeelding 3 van 3
    • Using your index finger lift and remove the battery from the phone.
  3. LG Chocolate 3 Rear Case Replacement, Rear Case: stap 3, afbeelding 1 van 1
    • Use the pointed end of the spudger to pull out the plastic inserts that are located on the left and right-hand corners.
    • If needed, use the tip of a push pin instead of the spudger to remove the plastic inserts.
  4. LG Chocolate 3 Rear Case Replacement: stap 4, afbeelding 1 van 1
    • Using a Phillips #00 screwdriver, remove the six 3mm long screws found along the edges of the phone.
    • If needed, use tweezers to remove loose screws from the recessed holes.
    • Screws are small, therefore, they should be placed in a secure location to prevent misplacement.
  5. LG Chocolate 3 Rear Case Replacement: stap 5, afbeelding 1 van 2 LG Chocolate 3 Rear Case Replacement: stap 5, afbeelding 2 van 2
    • Pull the rear case up using the spudger.
    • The rear case is connected to the right side of the phone via red and blue cables, be careful not to pull these cables out.
    • The volume control buttons on the side might fall out of their sockets. Carefully replace them with a pair of tweezers before you reassemble the rear case.
  6. LG Chocolate 3 Rear Case Replacement: stap 6, afbeelding 1 van 1
    • Use tweezers to pull the clear end of the red and blue speaker cables away from motherboard.
  7. LG Chocolate 3 Rear Case Replacement: stap 7, afbeelding 1 van 2 LG Chocolate 3 Rear Case Replacement: stap 7, afbeelding 2 van 2
    • Carefully remove the rear case from the phone.
Conclusie
Brenna Yagade
40 Reputatie
6 handleidingen geschreven
Cal Poly, Team 12-35, Amido Spring 2013 Lid van Cal Poly, Team 12-35, Amido Spring 2013
CPSU-AMIDO-S13S12G35
5 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 10
Altijd: 296
