Inleiding
This guide explains how to remove the front plastic screen covering from the phone. This is a fairly simple guide for the LG CU515 SKU 64743 Device. Removing the front screen covering will require only a plastic pry tool. This guide will take you through each step in detail so as to make the process as easy as possible.
Wat je nodig hebt
Carefully pry around the crevice of the entire plastic screen covering using a pry bar or some other type of sharp tool.
Once you have pried all the way around, using tweezers to pull the plastic screen completely off.
