Inleiding
This guide will explain how to remove the camera lens. This is a fairly difficult guide for the LG CU515 SKU 64743 Device. Removing the camera lens will require many tools and steps. However, this guide will take you through each step in detail so as to make the process as easy as possible.
Wat je nodig hebt
Stap 1 Front Cover
Voorzichtig: stappen 1-5 komen van een handleiding die in bewerking is.
Separate the top half of the clamshell from the bottom half by first locating the two hinges.
Carefully pull to one side and immediately up. The top part should pop out of the hinge. Next slide the opposite direction to pull out of the other hinge.
Rotate the phone 180 degrees and locate the small black square shown in the photo. Using the tweezers, pinch the raised circular lens casing and remove.
