Ga door naar hoofdinhoud
LG CU515 Motherboard Replacement
Wat je nodig hebt
  1. LG CU515 Motherboard Replacement, Battery: stap 1, afbeelding 1 van 2 LG CU515 Motherboard Replacement, Battery: stap 1, afbeelding 2 van 2
    • Use your thumb to press down and slide off the back cover of the phone.
  2. LG CU515 Motherboard Replacement: stap 2, afbeelding 1 van 3 LG CU515 Motherboard Replacement: stap 2, afbeelding 2 van 3 LG CU515 Motherboard Replacement: stap 2, afbeelding 3 van 3
    • Take out the battery by levering it out towards the bottom of the phone.
  3. LG CU515 Motherboard Replacement, Motherboard: stap 3, afbeelding 1 van 1
    • Push the spudger between each of the two rubber cushions and the body of the phone. Then turn the spudger to pop each cushion out.
  4. LG CU515 Motherboard Replacement: stap 4, afbeelding 1 van 1
    • Remove six 3.0 mm Phillips #00 screws from the back of the phone.
  5. LG CU515 Motherboard Replacement: stap 5, afbeelding 1 van 3 LG CU515 Motherboard Replacement: stap 5, afbeelding 2 van 3 LG CU515 Motherboard Replacement: stap 5, afbeelding 3 van 3
    • Push the spudger into the crack separating the two pieces of the phone.
    • Then use the plastic opening tools to pry the back off by separating the two pieces of the phone.
    • Repeat as necessary around the perimeter of the phone until the casing pops off. Use force as necessary without breaking the cover.
    • The back is attached to the motherboard by a wire, so don't pull the back casing off just yet.
  6. LG CU515 Motherboard Replacement: stap 6, afbeelding 1 van 1
    • Gently pull the wire up from the motherboard, separating the back of the phone and the motherboard.
  7. LG CU515 Motherboard Replacement: stap 7, afbeelding 1 van 1
    • Remove the plastic tab connecting the screen to the motherboard by pulling the tab up from the board.
  8. LG CU515 Motherboard Replacement: stap 8, afbeelding 1 van 1
    • Gently grasp one of the corners of the motherboard and simply lift it straight up out of the phone casing.
    • Replace the motherboard with a new one.
Conclusie
Zack Mintzer
1 Reputatie
6 handleidingen geschreven
Cal Poly, Team 21-55, Johann Spring 2013 Lid van Cal Poly, Team 21-55, Johann Spring 2013
CPSU-JOHANN-S13S21G55
4 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 10
Altijd: 348
