Ga door naar hoofdinhoud
LG CG180 Circuit Board Replacement
Wat je nodig hebt
  1. LG CG180 Circuit Board Replacement, Battery: stap 1, afbeelding 1 van 1
    • Power down the cell phone by pressing and holding down the red "end call" button.
  2. LG CG180 Circuit Board Replacement: stap 2, afbeelding 1 van 1
    • Turn the phone screen-down so you are looking at the back cover.
  3. LG CG180 Circuit Board Replacement: stap 3, afbeelding 1 van 2 LG CG180 Circuit Board Replacement: stap 3, afbeelding 2 van 2
    • Slide the back cover down using your finger to remove the cover from the phone.
  4. LG CG180 Circuit Board Replacement: stap 4, afbeelding 1 van 1
    • Place your finger at the top of the battery in small gap.
  5. LG CG180 Circuit Board Replacement: stap 5, afbeelding 1 van 1
    • Press downward while pulling outward to remove the battery.
  6. LG CG180 Circuit Board Replacement, Hardshell Case: stap 6, afbeelding 1 van 1
    • Remove all four screws on the back of the phone using a Phillips #00 screwdriver.
  7. LG CG180 Circuit Board Replacement: stap 7, afbeelding 1 van 1
    • Insert a plastic opening tool in the seam.
  8. LG CG180 Circuit Board Replacement: stap 8, afbeelding 1 van 2 LG CG180 Circuit Board Replacement: stap 8, afbeelding 2 van 2
    • Run the tool along the seam to release all the tabs.
  9. LG CG180 Circuit Board Replacement: stap 9, afbeelding 1 van 2 LG CG180 Circuit Board Replacement: stap 9, afbeelding 2 van 2
    • Pull the phone back cover off once all the tabs are released.
  10. LG CG180 Circuit Board Replacement: stap 10, afbeelding 1 van 1
    • Push the contents of the phone away from the hardshell case by applying pressure to the keypad with both thumbs.
  11. LG CG180 Circuit Board Replacement: stap 11, afbeelding 1 van 1
    • The hardshell case is separated from the rest of the phone.
  12. LG CG180 Circuit Board Replacement, Keypad: stap 12, afbeelding 1 van 2 LG CG180 Circuit Board Replacement, Keypad: stap 12, afbeelding 2 van 2
    • Separate keypad from circuit board by turning it upside down and allowing it to fall off.
  13. LG CG180 Circuit Board Replacement, Display: stap 13, afbeelding 1 van 1
    • Place the circuit board with the display facing downward.
  14. LG CG180 Circuit Board Replacement: stap 14, afbeelding 1 van 1
    • Use thumb to release both white clips at the top of the circuit board.
    • Be careful with the display because it is still attached by electrical tape.
  15. LG CG180 Circuit Board Replacement: stap 15, afbeelding 1 van 2 LG CG180 Circuit Board Replacement: stap 15, afbeelding 2 van 2
    • Once both clips are released, turn over the circuit board so that the display is facing upward.
    • Carefully lift the display from the left side and open to the right.
  16. LG CG180 Circuit Board Replacement: stap 16, afbeelding 1 van 1
    • Carefully remove the electrical tape from the display.
  17. LG CG180 Circuit Board Replacement: stap 17, afbeelding 1 van 1
    • The display is disconnected from the circuit board.
  18. LG CG180 Circuit Board Replacement, Circuit Board: stap 18, afbeelding 1 van 1
    • The circuit board is separated from the rest of the phone.
Conclusie
Alex Jacobs
5 Reputatie
4 handleidingen geschreven
Cal Poly, Team 14-42, Regan Winter 2010 Lid van Cal Poly, Team 14-42, Regan Winter 2010
CPSU-REGAN-W10S14G42
4 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 6
Altijd: 2,816
