Ga door naar hoofdinhoud
LG CF360 Rear Speaker Replacement
Wat je nodig hebt
  1. LG CF360 Rear Speaker Replacement, Battery: stap 1, afbeelding 1 van 2 LG CF360 Rear Speaker Replacement, Battery: stap 1, afbeelding 2 van 2
    • On the back of the phone, place your thumb on the three raised bumps and slide the back cover upward.
  2. LG CF360 Rear Speaker Replacement: stap 2, afbeelding 1 van 1
    • Lift and remove the battery.
  3. LG CF360 Rear Speaker Replacement, Back Cover: stap 3, afbeelding 1 van 2 LG CF360 Rear Speaker Replacement, Back Cover: stap 3, afbeelding 2 van 2
    • Remove the two screw covers at the top of phone with tweezers.
  4. LG CF360 Rear Speaker Replacement: stap 4, afbeelding 1 van 1
    • Remove the six Phillips #000 (3mm) screws.
  5. LG CF360 Rear Speaker Replacement: stap 5, afbeelding 1 van 3 LG CF360 Rear Speaker Replacement: stap 5, afbeelding 2 van 3 LG CF360 Rear Speaker Replacement: stap 5, afbeelding 3 van 3
    • Use the plastic opening tool to pry the back cover off. Insert the tool between the back cover and red mid section and go around the entire phone.
    • The plastic side buttons fall out when you take the back cover off.
    • The back cover is connected to the speaker by red and black wires.
  6. LG CF360 Rear Speaker Replacement: stap 6, afbeelding 1 van 1
    • Use the tweezers to remove the red and black wires connecting the speaker to the green motherboard by pinching the sides of the plastic base near the motherboard.
    • Set the back cover with the speaker aside.
  7. LG CF360 Rear Speaker Replacement, Rear Speaker: stap 7, afbeelding 1 van 1
    • Use the plastic opening tool to pry the speaker cover off of the phone.
  8. LG CF360 Rear Speaker Replacement: stap 8, afbeelding 1 van 1
    • Use the plastic opening tool to pry the speaker out of the back cover.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Annie White
262 Reputatie
2 handleidingen geschreven
Cal Poly, Team 4-27, Amido Fall 2013 Lid van Cal Poly, Team 4-27, Amido Fall 2013
CPSU-AMIDO-F13S4G27
4 Leden
19 handleidingen geschreven
Één opmerking
Where can I buy the replacement parts?
Sarah Birkett - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 16
Altijd: 260
