Ga door naar hoofdinhoud
LG CF360 Motherboard Replacement
Wat je nodig hebt
  1. LG CF360 Motherboard Replacement, Battery: stap 1, afbeelding 1 van 2 LG CF360 Motherboard Replacement, Battery: stap 1, afbeelding 2 van 2
    • On the back of the phone, place your thumb on the three raised bumps and slide the back cover upward.
  2. LG CF360 Motherboard Replacement: stap 2, afbeelding 1 van 1
    • Lift and remove the battery.
  3. LG CF360 Motherboard Replacement, Back Cover: stap 3, afbeelding 1 van 2 LG CF360 Motherboard Replacement, Back Cover: stap 3, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Koop
    • Remove the two screw covers at the top of phone with tweezers.
  4. LG CF360 Motherboard Replacement: stap 4, afbeelding 1 van 1
    • Remove the six Phillips #000 (3mm) screws.
  5. LG CF360 Motherboard Replacement: stap 5, afbeelding 1 van 3 LG CF360 Motherboard Replacement: stap 5, afbeelding 2 van 3 LG CF360 Motherboard Replacement: stap 5, afbeelding 3 van 3
    • Use the plastic opening tool to pry the back cover off. Insert the tool between the back cover and red mid section and go around the entire phone.
    • The plastic side buttons fall out when you take the back cover off.
    • The back cover is connected to the speaker by red and black wires.
  6. LG CF360 Motherboard Replacement: stap 6, afbeelding 1 van 1
    • Use the tweezers to remove the red and black wires connecting the speaker to the green motherboard by pinching the sides of the plastic base near the motherboard.
    • Set the back cover with the speaker aside.
  7. LG CF360 Motherboard Replacement, Motherboard: stap 7, afbeelding 1 van 2 LG CF360 Motherboard Replacement, Motherboard: stap 7, afbeelding 2 van 2
    • Use the plastic opening tool to gently lift the snapped-in motherboard from the front panel.
    • An orange ribbon from the LCD is connected to the underside of the motherboard, so do not force the motherboard from the rest of the phone yet.
  8. LG CF360 Motherboard Replacement: stap 8, afbeelding 1 van 1
    • Gently remove the blue transparent tape from the connector.
  9. LG CF360 Motherboard Replacement: stap 9, afbeelding 1 van 1
    • With the plastic opening tool, gently pry the LCD connector from the motherboard.
    • Set the motherboard aside.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Aaron
167 Reputatie
1 Handleiding geschreven
Cal Poly, Team 4-27, Amido Fall 2013 Lid van Cal Poly, Team 4-27, Amido Fall 2013
CPSU-AMIDO-F13S4G27
4 Leden
19 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 4
Altijd: 990
