Ga door naar hoofdinhoud
LG BP220 Disc Drive Replacement
Wat je nodig hebt
  1. LG BP220 Disc Drive Replacement, Disc Drive: stap 1, afbeelding 1 van 2 LG BP220 Disc Drive Replacement, Disc Drive: stap 1, afbeelding 2 van 2
    • Ensure the device is unplugged to prevent shocks.
    • Remove the three black 3/16” Phillips #2 screws from the backside of the player.
    • With the backside (audio/video jacks) facing you, lift the part of the cover closer to you and pull until it is off.
  2. LG BP220 Disc Drive Replacement: stap 2, afbeelding 1 van 1
    • Using your fingers, pull the three tape-like cables to disconnect the disc drive from the green motherboard.
  3. LG BP220 Disc Drive Replacement: stap 3, afbeelding 1 van 3 LG BP220 Disc Drive Replacement: stap 3, afbeelding 2 van 3 LG BP220 Disc Drive Replacement: stap 3, afbeelding 3 van 3
    • Unhinge the tabs that attach the front panel to the unit:
    • Two tabs on the disc drive
    • Two tabs on the left and right side of the player
    • Be careful when handling these tabs. They are very fragile and can be easily broken.
    • Three tabs on the underside of the player
    • Pull panel away from case.
    • If the panel does not come off right away, be sure to check if tabs have inadvertently switched back to their locked position.
  4. LG BP220 Disc Drive Replacement: stap 4, afbeelding 1 van 2 LG BP220 Disc Drive Replacement: stap 4, afbeelding 2 van 2
    • Remove the two black 3/16” Phillips #2 mounting screws from the left and right side of the disc drive.
    • With the front side facing you lift the front of disc drive and pull out to remove.
Conclusie
6 andere personen hebben deze handleiding voltooid.
Bart Quicho
520 Reputatie
3 handleidingen geschreven
UW Tacoma, Team 1-1, Rose Winter 2015 Lid van UW Tacoma, Team 1-1, Rose Winter 2015
UWT-ROSE-W15S1G1
4 Leden
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 73
Altijd: 9,376
