Ga door naar hoofdinhoud
LG Aristo MS210 Front and Rear Camera Replacement
Wat je nodig hebt
  1. LG Aristo MS210 Front and Rear Camera Replacement, Battery: stap 1, afbeelding 1 van 3 LG Aristo MS210 Front and Rear Camera Replacement, Battery: stap 1, afbeelding 2 van 3 LG Aristo MS210 Front and Rear Camera Replacement, Battery: stap 1, afbeelding 3 van 3
    • Insert the spudger into the notch on the bottom left side of the phone.
    • Apply light pressure to remove the back cover.
  2. LG Aristo MS210 Front and Rear Camera Replacement: stap 2, afbeelding 1 van 2 LG Aristo MS210 Front and Rear Camera Replacement: stap 2, afbeelding 2 van 2
    • Insert the spudger into the notch located on the bottom middle of the battery.
    • Apply light pressure to remove the battery.
  3. LG Aristo MS210 Front and Rear Camera Replacement, Command Button: stap 3, afbeelding 1 van 3 LG Aristo MS210 Front and Rear Camera Replacement, Command Button: stap 3, afbeelding 2 van 3 LG Aristo MS210 Front and Rear Camera Replacement, Command Button: stap 3, afbeelding 3 van 3
    • Use the PH000 bit unscrew the ten 3.4mm screws as highlighted.
    • Use the spudger to remove the inner shell.
    • Flip the inner shell over to expose the clips holding the command button.
  4. LG Aristo MS210 Front and Rear Camera Replacement: stap 4, afbeelding 1 van 3 LG Aristo MS210 Front and Rear Camera Replacement: stap 4, afbeelding 2 van 3 LG Aristo MS210 Front and Rear Camera Replacement: stap 4, afbeelding 3 van 3
    • Use the spudger disconnect the three clips holding in the command button as highlighted.
    • Remove the command button.
  5. LG Aristo MS210 Front and Rear Camera Replacement, Front and Rear Camera: stap 5, afbeelding 1 van 3 LG Aristo MS210 Front and Rear Camera Replacement, Front and Rear Camera: stap 5, afbeelding 2 van 3 LG Aristo MS210 Front and Rear Camera Replacement, Front and Rear Camera: stap 5, afbeelding 3 van 3
    • Use the spudger to disconnect the ZIF connector securing the front-facing camera.
  6. LG Aristo MS210 Front and Rear Camera Replacement: stap 6, afbeelding 1 van 3 LG Aristo MS210 Front and Rear Camera Replacement: stap 6, afbeelding 2 van 3 LG Aristo MS210 Front and Rear Camera Replacement: stap 6, afbeelding 3 van 3
    • Use the spudger disconnect the ZIF connector securing the back-facing camera.
  7. LG Aristo MS210 Front and Rear Camera Replacement: stap 7, afbeelding 1 van 1
    • Remove both the front and back facing cameras.
Conclusie
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 221
