Inleiding
If the keypad on your LG 440G phone has worn out or unresponsive, you may want to replace it, Use this step-by-step guide to learn how to change the keypad.
Wat je nodig hebt
Locate the small rounded recess to get access to the battery
Gently, lift the battery
Use a Phillips #00 screw driver to remove six screws.
Run the plastic opening tool along the edge of the phone to release the casing cover.
Lift the casing cover.
Use the plastic opening tool or fingernail to lift the rectangular piece up. The piece can be identified by the orange tape attached to it.
Remove the keypad from the phone by pushing the keypad itself out from the front of the phone. Then, lift the keypad out of the casing to separate the keypad from the casing.
