Inleiding
Before completing this replacement guide, it is important to unplug the device. This replacement guide will show how to replace the camera from the LG 305C.
Wat je nodig hebt
Pry open the back case on the device with a plastic opening tool and remove it.
Dislodge the microSD card from the microSD card slot using your index finger and remove it.
Remove the three 4 mm screws using a JIS screwdriver with a J000 head from the bottom part of the internal casing.
Pry the screen from the internal circuit board with a plastic opening tool and remove it.
Pry the camera from the internal circuit board with the plastic opening tool and remove it.
