Ga door naar hoofdinhoud
LERSTA Floor Lamp Screw Terminal Replacement
Wat je nodig hebt
  1. LERSTA Floor Lamp Screw Terminal Replacement, Screw Terminal: stap 1, afbeelding 1 van 2 LERSTA Floor Lamp Screw Terminal Replacement, Screw Terminal: stap 1, afbeelding 2 van 2
    • Unplug the lamp.
  2. LERSTA Floor Lamp Screw Terminal Replacement: stap 2, afbeelding 1 van 1
    • Rotate the bulb counterclockwise to remove the light bulb.
  3. LERSTA Floor Lamp Screw Terminal Replacement: stap 3, afbeelding 1 van 1
    • Rotate the lamp shade counterclockwise.
  4. LERSTA Floor Lamp Screw Terminal Replacement: stap 4, afbeelding 1 van 1
    • Take the three parts aside after dismantling the lamp shade.
  5. LERSTA Floor Lamp Screw Terminal Replacement: stap 5, afbeelding 1 van 1
    • Dismantle the lamp shaft by rotating it counterclockwise.
  6. LERSTA Floor Lamp Screw Terminal Replacement: stap 6, afbeelding 1 van 1
    • Use a Phillips screwdriver to remove the two 3 mm screws from the silver cover.
    • Pull down both the silver cover and the black screw terminal.
  7. LERSTA Floor Lamp Screw Terminal Replacement: stap 7, afbeelding 1 van 1
    • Separate the light bulb socket from the silver cover by pulling the silver metal hasp in right-downward direction towards the lamp shaft.
    • Exert force on the both left and right hand sides of the hasp and then pull the hasp downward.
  8. LERSTA Floor Lamp Screw Terminal Replacement: stap 8, afbeelding 1 van 1
    • Replace the old bulb socket with a newly-purchased one.
Conclusie
Replacing the screw terminal of the floor lamp is relatively easy, but be cautious to deal with the step of the substitution of the light socket.
[deleted]
157 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 18
Altijd: 1,154
