Ga door naar hoofdinhoud
LCD X2gen Display disassembly
Wat je nodig hebt
  1. LCD X2gen Display disassembly, Display: stap 1, afbeelding 1 van 1
    • X2gen 22 lcd Screen repair guide
  2. LCD X2gen Display disassembly: stap 2, afbeelding 1 van 1
    • Power board displaying the capacitors to be replaced
  3. LCD X2gen Display disassembly: stap 3, afbeelding 1 van 1
    • Display viewed laying face down on the working table (my dining table)
    • Remove the 6 screws. 4 on the corners and 2 middle bottom.
  4. LCD X2gen Display disassembly: stap 4, afbeelding 1 van 1
    • Remove front bezel by lifting softly starting from the middle and moving out to the corners.
  5. LCD X2gen Display disassembly: stap 5, afbeelding 1 van 1
    • Top middle
  6. LCD X2gen Display disassembly: stap 6, afbeelding 1 van 1
    • Front bezel removed.
    • Observe: the control board, bottom right.
    • exposed screws on both sides (4 left, 4 right) holding the LCD to the back cover.
  7. LCD X2gen Display disassembly: stap 7, afbeelding 1 van 1
    • Prepare to remove the 4 screws on each side to lift the LCD. Do not try to remove it after unscrewing the 8 screws. There are cables connected on the back.
    • This pic shows the right side
  8. LCD X2gen Display disassembly: stap 8, afbeelding 1 van 1
    • This pic shows the left side
  9. LCD X2gen Display disassembly: stap 9, afbeelding 1 van 2 LCD X2gen Display disassembly: stap 9, afbeelding 2 van 2
    • Lift carefully about 2 inch to expose the back light connections, 2 pink and 2 white.
    • Slide the monitor to the left about 3-4 inch. to have access to the connections.
  10. LCD X2gen Display disassembly: stap 10, afbeelding 1 van 1
    • Carefully, unplug both connectors
  11. LCD X2gen Display disassembly: stap 11, afbeelding 1 van 2 LCD X2gen Display disassembly: stap 11, afbeelding 2 van 2
    • After removing the connectors, slide it about 3-5 inches to the right to have access to the data connector and ground
  12. LCD X2gen Display disassembly: stap 12, afbeelding 1 van 1
    • Remove the data connector and ground.
    • Lift display. Is now completely free
Conclusie
Aleks
201 Reputatie
1 Handleiding geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 17
Afgelopen 30 dagen: 59
Altijd: 2,037
