Ga door naar hoofdinhoud
Kyocera Zio M6000 Digitizer Replacement
Wat je nodig hebt
  1. Kyocera Zio M6000 Digitizer Replacement, Battery: stap 1, afbeelding 1 van 2 Kyocera Zio M6000 Digitizer Replacement, Battery: stap 1, afbeelding 2 van 2
    • Press down on the back of the phone, applying moderate pressure.
    • Slide the back casing down to separate it.
    Vraag FixBot
  2. Kyocera Zio M6000 Digitizer Replacement: stap 2, afbeelding 1 van 2 Kyocera Zio M6000 Digitizer Replacement: stap 2, afbeelding 2 van 2
    • Remove the back casing to expose the battery.
    • Use a plastic spudger to lift the battery out using the battery's groove on its top left corner.
    Vraag FixBot
  3. Kyocera Zio M6000 Digitizer Replacement, Motherboard: stap 3, afbeelding 1 van 2 Kyocera Zio M6000 Digitizer Replacement, Motherboard: stap 3, afbeelding 2 van 2
    • Remove the six 3.18 mm screws using a Phillips 00 screwdriver.
    Vraag FixBot
  4. Kyocera Zio M6000 Digitizer Replacement: stap 4, afbeelding 1 van 2 Kyocera Zio M6000 Digitizer Replacement: stap 4, afbeelding 2 van 2
    • Insert the flat end of the spudger between the front and back panels, and pry it apart by running the spudger along the side to further separate them.
    • Go all the way around, prying as you go, until the back casing completely separates from the rest of the phone.
    Vraag FixBot
  5. Kyocera Zio M6000 Digitizer Replacement: stap 5, afbeelding 1 van 3 Kyocera Zio M6000 Digitizer Replacement: stap 5, afbeelding 2 van 3 Kyocera Zio M6000 Digitizer Replacement: stap 5, afbeelding 3 van 3
    • Unclip the two flex cables -- a small one located on the left side on the lower half of the motherboard, and a longer one on the right side, higher up.
    Vraag FixBot
  6. Kyocera Zio M6000 Digitizer Replacement: stap 6, afbeelding 1 van 3 Kyocera Zio M6000 Digitizer Replacement: stap 6, afbeelding 2 van 3 Kyocera Zio M6000 Digitizer Replacement: stap 6, afbeelding 3 van 3
    • Pry out the earpiece speaker using the spudger.
    • Pry out the vibration motor using the spudger.
    Vraag FixBot
  7. Kyocera Zio M6000 Digitizer Replacement: stap 7, afbeelding 1 van 2 Kyocera Zio M6000 Digitizer Replacement: stap 7, afbeelding 2 van 2
    • Place the flat end of the spudger underneath the digitizer connector and pry it up to disconnect it.
    Vraag FixBot
  8. Kyocera Zio M6000 Digitizer Replacement: stap 8, afbeelding 1 van 3 Kyocera Zio M6000 Digitizer Replacement: stap 8, afbeelding 2 van 3 Kyocera Zio M6000 Digitizer Replacement: stap 8, afbeelding 3 van 3
    • Remove the sticker to uncover the screws underneath.
    • Remove the six 1.59 mm screws using a Phillips 00 screwdriver.
    Vraag FixBot
  9. Kyocera Zio M6000 Digitizer Replacement: stap 9, afbeelding 1 van 3 Kyocera Zio M6000 Digitizer Replacement: stap 9, afbeelding 2 van 3 Kyocera Zio M6000 Digitizer Replacement: stap 9, afbeelding 3 van 3
    • Lift the bottom portion of the motherboard away from the front panel.
    • Do not forcefully pull the components apart as there is another connector on the underside of the motherboard attaching it to the panel.
    • Insert the flat end of the spudger in between the panel and motherboard to unfasten the connector.
    Vraag FixBot
  10. Kyocera Zio M6000 Digitizer Replacement, Digitizer: stap 10, afbeelding 1 van 3 Kyocera Zio M6000 Digitizer Replacement, Digitizer: stap 10, afbeelding 2 van 3 Kyocera Zio M6000 Digitizer Replacement, Digitizer: stap 10, afbeelding 3 van 3
    • Remove the two rubber pieces from the ends of the panel.
    Vraag FixBot
  11. Kyocera Zio M6000 Digitizer Replacement: stap 11, afbeelding 1 van 3 Kyocera Zio M6000 Digitizer Replacement: stap 11, afbeelding 2 van 3 Kyocera Zio M6000 Digitizer Replacement: stap 11, afbeelding 3 van 3
    • Remove the red Power button and green Talk button from the bottom of the casing.
    • Remove the trackball, also at the bottom of the casing.
    Vraag FixBot
  12. Kyocera Zio M6000 Digitizer Replacement: stap 12, afbeelding 1 van 3 Kyocera Zio M6000 Digitizer Replacement: stap 12, afbeelding 2 van 3 Kyocera Zio M6000 Digitizer Replacement: stap 12, afbeelding 3 van 3
    • Pry the bottom edge of the bezel with the flat end of the spudger.
    • Carefully run the spudger up the sides until the digitizer is free.
    Vraag FixBot
Conclusie
Scott Nguyen
522 Reputatie
3 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 45
Altijd: 620
