Ga door naar hoofdinhoud
Kyocera QCP-2035 Display Replacement
Wat je nodig hebt
  1. Kyocera QCP-2035 Display Replacement, Remove Back Cover: stap 1, afbeelding 1 van 3 Kyocera QCP-2035 Display Replacement, Remove Back Cover: stap 1, afbeelding 2 van 3 Kyocera QCP-2035 Display Replacement, Remove Back Cover: stap 1, afbeelding 3 van 3
    • When looking at the back of the phone, you will see a horizontal line and three raised segments of plastic in the form of a triangle.
    • Place thumb on top of the triangle and press into the phone while sliding your thumb towards the bottom of the phone.
    • In 5 mm it will stop sliding.
  2. Kyocera QCP-2035 Display Replacement: stap 2, afbeelding 1 van 3 Kyocera QCP-2035 Display Replacement: stap 2, afbeelding 2 van 3 Kyocera QCP-2035 Display Replacement: stap 2, afbeelding 3 van 3
    • Grab the bottom of the back cover with your other hand and pull the cover the rest of the way off.
    • Turn the phone over slowly. The battery will fall out on its own.
  3. Kyocera QCP-2035 Display Replacement: stap 3, afbeelding 1 van 3 Kyocera QCP-2035 Display Replacement: stap 3, afbeelding 2 van 3 Kyocera QCP-2035 Display Replacement: stap 3, afbeelding 3 van 3
    • Rotate the phone so the bottom is facing you. There is a small indent on the plastic face.
    • Using the tip of your fingernail or a spudger, pry the cover away from the rest of the phone.
    • Once the cover starts to part, keep separating until the top notches detach.
  4. Kyocera QCP-2035 Display Replacement: stap 4, afbeelding 1 van 3 Kyocera QCP-2035 Display Replacement: stap 4, afbeelding 2 van 3 Kyocera QCP-2035 Display Replacement: stap 4, afbeelding 3 van 3
    • With the cover plate separated, you will see (6) T6x11mm torx screws recessed in the white plastic.
    • Remove screws.
    • The white plastic face plate lifts right off, exposing the main board.
  5. Kyocera QCP-2035 Display Replacement, Display: stap 5, afbeelding 1 van 3 Kyocera QCP-2035 Display Replacement, Display: stap 5, afbeelding 2 van 3 Kyocera QCP-2035 Display Replacement, Display: stap 5, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Koop
    • Lift the display straight up, by either grabbing it on it's sides, or sliding a pair of tweezers between the screen and the main board.
    • There are four straight plastic pins on the underside corners of the screen that hold it in place.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Scott Whitney
301 Reputatie
3 handleidingen geschreven
USF Tampa, Team 5-3, Brown Winter 2015 Lid van USF Tampa, Team 5-3, Brown Winter 2015
USFT-BROWN-W15S5G3
4 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 11
Altijd: 187
