Ga door naar hoofdinhoud
Inleiding
Removing the rear casing is simple and easy with the right tools and a little effort. This is also the initial process to access the phone's internal circuitry.
Onderdelen
Geen onderdelen opgegeven.
  1. Wedge the opening device into the side crease of the phone. Wedge the opening device into the side crease of the phone.
    • Wedge the opening device into the side crease of the phone.
  2. iPhone Batterij Fix Kits
    Slechts $29.99
    Buy Now
    Slechts $29.99
    Buy Now
  3. Slide the opening device downward to dis-join the rear casing from the front casing. Continue around all edges. Slide the opening device downward to dis-join the rear casing from the front casing. Continue around all edges.
    • Slide the opening device downward to dis-join the rear casing from the front casing. Continue around all edges.
  4. Remove the back casing from the front casing. Force may be necessary.
    • Remove the back casing from the front casing. Force may be necessary.
Conclusie
Erica
101 Reputatie
3 handleidingen geschreven
James Madison, Team 1-49, Allen Fall 2011 Lid van James Madison, Team 1-49, Allen Fall 2011
JMU-ALLEN-F11S1G49
3 Leden
8 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 0
Afgelopen 30 Dagen: 0
Altijd: 662
