Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Onderdelen & Gereedschap
Inleiding
Before beginning the project necessary tools needed will be a #00 screwdriver and flat prying device. You need to be prepared to collect the tiny screws that will be removed.
Onderdelen
Geen onderdelen opgegeven.
  1. Open phone
    • Open phone
  2. Remove the four tiny front screen screws with a screw driver Remove the four tiny front screen screws with a screw driver
    • Remove the four tiny front screen screws with a screw driver
  3. Nintendo Switch-kits
    Een snelle oplossing die je weer mee laat doen
    Koop Switchkits
    Koop Switchkits
  4. Use prying tool to open the side of the screen and work you way around the screen. Use prying tool to open the side of the screen and work you way around the screen.
    • Use prying tool to open the side of the screen and work you way around the screen.
  5. Carefully remove screen after prying it lose, exposing the bottom screen and parts Carefully remove screen after prying it lose, exposing the bottom screen and parts
    • Carefully remove screen after prying it lose, exposing the bottom screen and parts
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Kimberlyn
31 Reputatie
1 Handleiding geschreven
James Madison, Team 1-49, Allen Fall 2011 Lid van James Madison, Team 1-49, Allen Fall 2011
JMU-ALLEN-F11S1G49
3 Leden
8 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 925
