Inleiding
This guide will step you through how to replace the headphone jack on the Kyocera Hydro Vibe. This replacement is needed if the headphone jack does not produce sound when headphones are plugged into it. The repair should take about an hour. You will need to purchase a new headphone jack. You will also need a spudger and a Phillips #000 screwdriver. There are no foreseen hazards. You will want to be careful when taking apart the phone as to not damage it further.
Wat je nodig hebt
Één andere persoon heeft deze handleiding voltooid.
