Ga door naar hoofdinhoud
Kyocera Hydro Vibe Camera Button Replacement
Wat je nodig hebt
  1. Kyocera Hydro Vibe Camera Button Replacement, Battery: stap 1, afbeelding 1 van 1
    • Make sure that the device is turned off before beginning.
    • Look for a small indentation on the bottom of the phone.
    • Insert the plastic opening tool into the indentation and lift off the back casing.
  2. Kyocera Hydro Vibe Camera Button Replacement: stap 2, afbeelding 1 van 3 Kyocera Hydro Vibe Camera Button Replacement: stap 2, afbeelding 2 van 3 Kyocera Hydro Vibe Camera Button Replacement: stap 2, afbeelding 3 van 3
    • The large white component is the battery. Look for a small indentation under the arrow that says "LIFT."
    • Place the plastic opening tool in the indentation and lift the battery out of the socket.
  3. Kyocera Hydro Vibe Camera Button Replacement, Trim: stap 3, afbeelding 1 van 1
    • Locate the screws holding the trim which are the four side screws on each corner.
    • Remove each screw with a Phillips screw driver #J00. The screws are 5mm Phillips.
  4. Kyocera Hydro Vibe Camera Button Replacement: stap 4, afbeelding 1 van 2 Kyocera Hydro Vibe Camera Button Replacement: stap 4, afbeelding 2 van 2
    • Locate the clasps holding the trim in place.
    • You will need to insert the metal spudger through the bottom of the trim and slowly push upwards to release the clasps.
  5. Kyocera Hydro Vibe Camera Button Replacement: stap 5, afbeelding 1 van 1
    • The trim is flimsy.
    • This is what the trim will look like once removed.
  6. Kyocera Hydro Vibe Camera Button Replacement, Camera Button: stap 6, afbeelding 1 van 3 Kyocera Hydro Vibe Camera Button Replacement, Camera Button: stap 6, afbeelding 2 van 3 Kyocera Hydro Vibe Camera Button Replacement, Camera Button: stap 6, afbeelding 3 van 3
    • Now that you have taken apart the trim, the camera button should be easily removable.
    • Locate the camera button. When looking at the back side (battery side), the camera button will be on the left side.
    • Take the camera button out with tweezers.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 5
Altijd: 266
